[Qgis-user] QGIS crashes when adding a plugin from QGIS Plugin Manager
Ramon Andiñach
custard at westnet.com.au
Sun Jun 24 18:05:05 PDT 2012
Ok, yes it will check the old repositories.
No, it's not offering me the problematic plugins.
-ramon.
On 25/06/2012, at 8:06, Ramon Andiñach <custard at westnet.com.au> wrote:
> I'm also noting that just updating via osgeo (on windows) will also leave the old repositories in play.
> Don't know if the plugin problem happens, will check when I get to work.
> -ramon.
> On 25/06/2012, at 05:14 , William Kyngesburye wrote:
>> I noticed this when testing the packaging on OS X. So I added a note to the OS X readme to delete the previous QGIS.app if there are problems. The OS X installer should be removing this stuff automatically, but it's not, mayeb I need to hardwire cleanup of old files... and someone should do something similar for Linux.
>> On Jun 24, 2012, at 4:01 PM, Etienne Tourigny wrote:
>>> These decorations are not python plugins, so why do they appear in the
>>> plugin manager?
>>> On Sun, Jun 24, 2012 at 5:57 PM, Giovanni Manghi
>>> <giovanni.manghi at faunalia.pt> wrote:
>>>> On Sun, 2012-06-24 at 17:47 -0300, Etienne Tourigny wrote:
>>>>> confirmed in linux ubuntu 11.10, so it's not a OSX problem
>>>>> On Sun, Jun 24, 2012 at 5:34 PM, Manuel Spínola <mspinola10 at gmail.com> wrote:
>>>>>> Update on the problem.
>>>>>> When I try to bring any of the 3 options on View/Decorations: "Copyright
>>>>>> Label", "North Arrow", "Scale Bar", from the QGIS Plugin Manager, QGIS
>>>>>> crashes. For all the other plugins is working fine.
>>>> in a clean installation that stuff should not be available anymore in
>>>> the "plugin manager" dialog.
>>>> Here on Ubuntu 12.04 activating one of the the decorations
>>>> (view->decorations) does not cause any crash.
>>>> cheers
>>>> -- Giovanni --
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
>> "Don't you even hate 'em?"
>> "What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
>> <Ha, ha> "And it might give 'em all stomach ulcers."
>> - Tarzan, on war
