[Qgis-user] any ideas how to get data from attribute table out of qgis
custard
custard at westnet.com.au
Sun Jun 24 19:09:05 PDT 2012
I've managed to pull a 103965 item shape file out on XP using Layers -> Save as and selecting CSV, and leaving everything else as default (which ment create attributes was unchecked). However, I don't have any calculated fields in that file.
This was on an aged toughbook running xp and QGIS 1.7.0 standalone.
If you were going to try the command line approch, then in the start menu in the QGIS folders there should be either MSYS or OSGEO. Either of these will start a command line shell that will include the QGIS bin folders in the path. You should then be able to use the command that Lee suggested.
Note that the form Lee gave assumes you have changed directory (cd) to folder that contains the offending file.
-ramon.
----- Original Message -----
From: "Giovanni Manghi" <giovanni.manghi at faunalia.pt>
To: "M.E.Dodd" <m.e.dodd at open.ac.uk>
Cc: qgis-user at lists.osgeo.org
Sent: Saturday, 23 June, 2012 6:56:29 PM GMT +08:00 Beijing / Chongqing / Hong Kong / Urumqi
Subject: Re: [Qgis-user] any ideas how to get data from attribute table out of qgis
> First the 'save as' .csv is indeed broken, infact I have never got it to work
> under windowsxp with any file of any size even though 'save as' works
> fine saving to other formats. Error message "Export to vector file failed. Error: creation of data source failed (OGR error:)"
tested again under win 7 and Linux and it works fine here
cheers
-- Giovanni --
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
