[Qgis-user] QGIS WEB Client / Qgis Server
Till Adams
adams at terrestris.de
Mon Jun 25 07:19:25 PDT 2012
looks like a problem with your qgis-project.
Did you use relative paths to the data?
Maybe it's better to start with one layer with a simple symbol for
testing whether any map will come out and then go to your "real"
project's data.
Also do not use complex classification first - this drives you to a
step-by-step setup of your webmap, where you test every step and as long
as you see the map, everything is all right ...
!!! And be aware of browser's cache which could be awful if you do not
see any changes in your map.
In this case vary the request e.g. by varying the bbox-param a little
bit. so that he browser can't just take the same image out of his cache ;-)
Have fun,
Till
On 25.06.2012 16:12, Kadu Machado wrote:
> Hi Till,,
> thanks for your attention...
> I followed your Windows How To install.. Actually, it oriented me to
> install the Qgis Server.... After I successful got the GetCapabilities,
> I installed the qgis-web-client without try the getMap...
> After i've seen your mail, i tried do just like you said... I tried the
> getmap before using QGIS-client....
> So, I tried this
> URL: http://localhost/qgis/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&SRS=EPSG:4326&REQUEST=GetMap&map=c:/projetos/censo.qgs&BBOX=-36.215710,6.817432,-9.700450,58.551008&WIDTH=500&HEIGHT=1000&LAYERS=censo_2010&FORMAT=image/png
> <http://srv-vibgeo01/qgis/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&SRS=EPSG:4326&REQUEST=GetMap&map=c:/projetos/censo.qgs&BBOX=-36.215710,6.817432,-9.700450,58.551008&WIDTH=500&HEIGHT=1000&LAYERS=censo_2010&FORMAT=image/png>
> I'm sure that the project name and layers are correct.
> This URL gives me no error in apache log or in Console of the
> Development tools of Google Chrome... However, gives me no maps either...
> I've noticed that the qgis-client was calling this
> url: http://localhost/qgis/qgis_mapserv.fcgi.exe?map=c:\projetos\redes.qgs&LAYERS=pk_kombiniert&FORMAT=image/jpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=174575.63035781,8246018.1303578,194419.36964219,8265861.8696422&WIDTH=300&HEIGHT=300
> <http://srv-vibgeo01/qgis/qgis_mapserv.fcgi.exe?map=c:\projetos\redes.qgs&LAYERS=pk_kombiniert&FORMAT=image/png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=174575.63035781,8246018.1303578,194419.36964219,8265861.8696422&WIDTH=300&HEIGHT=300>
> If I change the FORMAT=image/jpeg for FORMAT=image/png the error 500 is
> solved, but the map is not shown....
> I'm using the Apache/2.2.14 (Win32) mod_fcgid/2.3.6 configured
> Server built: Sep 28 2009 22:41:08
> Any other Idea?
> Regards,
> Kadu
> On Mon, Jun 25, 2012 at 9:18 AM, Till Adams <adams at terrestris.de
> <mailto:adams at terrestris.de>> wrote:
> Dear Kadu,
> this looks like an installation problem of your qgis-server as it is not
> able to deliver a map on a getmap-request. The labels and so are drawn
> by OpenLayers, the core of the QGIS client.
> It's easier to test the pure qgis-server installation first and try via
> the getmap request, before using QGIS-client as you have less
> dependencies.
> I tried my best for a windows-install howto, look here:
> http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial#Windows
> I would suggest to check this first.
> Regards, Till
> On 25.06.2012 14:12, Kadu Machado wrote:
> > Hi folks....
> > I have a little issue with Qgis WebClient over Windows....
> > When I access the qgis web client, the layers and labels are
> loaded and
> > are showed normally, but the map dont.... After the message
> loading map,
> > the map just dont open. The frame is still blank.
> > I notice that a Internal Error 500 occour:
> > 1. GET
> http://srv-vibgeo01/qgis/qgis_mapserv.fcgi.exe?map=c:\projetos\redes.qgs&LAYERS=pk_kombiniert&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=174575.63035781,8246018.1303578,194419.36964219,8265861.8696422&WIDTH=300&HEIGHT=300
> <http://srv-vibgeo01/qgis/qgis_mapserv.fcgi.exe?map=c:%5Cprojetos%5Credes.qgs&LAYERS=pk_kombiniert&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=174575.63035781,8246018.1303578,194419.36964219,8265861.8696422&WIDTH=300&HEIGHT=300
> <http://srv-vibgeo01/qgis/qgis_mapserv.fcgi.exe?map=c:%5Cprojetos%5Credes.qgs&LAYERS=pk_kombiniert&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=174575.63035781,8246018.1303578,194419.36964219,8265861.8696422&WIDTH=300&HEIGHT=300>>
> > 500 (Internal Server Error) OpenLayers.js:1000
> > <http://srv-vibgeo01/maps/libs/openlayers/OpenLayers.js>
> > Anyone has some ideia how to solve this problem???
> > "Quem quer fazer alguma coisa, encontra um meio. Quem não quer fazer
> > nada, encontra uma desculpa."
> > (Roberto Shinyashiki)
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> --> GO Mobile - jetzt WebGIS auch auf Smartphones <--
> ! Achtung - terrestris hat eine neue Adresse !
> terrestris GmbH & Co. KG
> Puetzchens Chaussee 56
> 53227 Bonn
> Germany
> Till Adams
> Geschaeftsfuehrung
> Tel: +49 (0)228 / 962 899-52
> <tel:%2B49%20%280%29228%20%2F%20962%20899-52>
> Mobile: +49 (0)151 / 25394429 <tel:%2B49%20%280%29151%20%2F%2025394429>
> Fax: +49 (0)228 / 962 899-57
> <tel:%2B49%20%280%29228%20%2F%20962%20899-57>
> adams at terrestris.de <mailto:adams at terrestris.de>
> http://www.terrestris.de
> Amtsgericht Bonn, HRA 6835
> Komplementaerin:
> terrestris Verwaltungs GmbH
> vertreten durch:
> Hinrich Paulsen, Till Adams
53227 Bonn
Germany
Till Adams
Geschaeftsfuehrung
Komplementaerin:
vertreten durch:
