[Qgis-user] QGIS - Mapinfo question
    Saber Razmjooei
    saber.razmjooei at lutraconsulting.co.uk
    Thu Jun 28 03:20:47 PDT 2012
As Alaister mentioned this is not a "binary" tab file from Mapinfo. You
can open it in a text editor and read the georferenced points,
indicating the pixel location and corresponding point on the ground.
If it is only a single tab you try to convert you can do it this way,
otherwise you need a Mapbasic tool to output jpgw for you.
Cheers
Saber
-----Original Message-----
To: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] QGIS - Mapinfo question
Date: Thu, 28 Jun 2012 09:59:26 +0000
The other main problem is that no, QGIS can't understand a .tab file for a raster, although you could write a script to convert .tab to .jgw (and vice versa).
Going the other direction, I'm not sure if Mapinfo can currently understand a world file, but it certainly looks like it couldn't in the past (Maybe your friend could see if the Mapbasic code at http://free-zg.t-com.hr/gorantt/geo/tfw2tab.htm works though...)
I presume it isn't an option to use an image format with embedding georeferencing information (e.g. you could use a geotiff with jpeg compression)?
Alister
> Date: Thu, 28 Jun 2012 11:36:34 +0200
> From: Bo Victor Thomsen <bo.victor.thomsen at gmail.com>
> Message-ID: <4FEC25A2.4060001 at gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
> Robert -
> AFAIK you can't (directly) write/edit geometries in tab based layer in
> QGIS.
> However, you can create a new _shape_ layer, do the adding/editing in
> this layer and then right-click the layer in the layer manager and
> choose the "Save As" menu option. The "save as" dialogue gives you the
> possibility to save the (shape) layer as a tab-file.
> Another option is directly to send the shape file to your MapInfo user.
> MapInfo can read and use shape files.
> Regards
> Bo Victor Thomsen
> Aestas-GIS
> Denmark
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
