[Qgis-user] QGIS - Mapinfo question
    Alister Hood
    Alister.Hood at synergine.com
    Thu Jun 28 02:59:26 PDT 2012
The other main problem is that no, QGIS can't understand a .tab file for a raster, although you could write a script to convert .tab to .jgw (and vice versa).
Going the other direction, I'm not sure if Mapinfo can currently understand a world file, but it certainly looks like it couldn't in the past (Maybe your friend could see if the Mapbasic code at http://free-zg.t-com.hr/gorantt/geo/tfw2tab.htm works though...)
I presume it isn't an option to use an image format with embedding georeferencing information (e.g. you could use a geotiff with jpeg compression)?
Alister
> Date: Thu, 28 Jun 2012 11:36:34 +0200
> From: Bo Victor Thomsen <bo.victor.thomsen at gmail.com>
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] QGIS - Mapinfo question
> Message-ID: <4FEC25A2.4060001 at gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
> Robert -
> AFAIK you can't (directly) write/edit geometries in tab based layer in
> QGIS.
> However, you can create a new _shape_ layer, do the adding/editing in
> this layer and then right-click the layer in the layer manager and
> choose the "Save As" menu option. The "save as" dialogue gives you the
> possibility to save the (shape) layer as a tab-file.
> Another option is directly to send the shape file to your MapInfo user.
> MapInfo can read and use shape files.
> Regards
> Bo Victor Thomsen
> Aestas-GIS
> Denmark
