[Qgis-user] import vector layer in manageR
Paulo van Breugel
p.vanbreugel at gmail.com
Thu Jun 28 05:58:15 PDT 2012
Hi Sebastiano
Thanks for the suggestion. Both are great tools, but I would use them
for different kind of tasks.
What I like about manageR is that it is basically an alternative CLI
(including syntax highlighting) combined with a simple GUI with some
predefined R relevant functions and with a loose integration of R in
QGIS (easy import/export of data between the two).
I like the Sextante plugin too, but it serves a different purpose (for
me). The R module does not seem to be a direct access to the R command
line (or at least I haven't found out how). This means it only gives
access to predefined functions or you have to create functions yourself
which can then be access through a GUI window. This is extremely useful
when working often with certain R functions, but without the option to
work directly from the command line and direct access to all R functions
(without having to define functions first), it does not offer the same
flexibility that manageR offers.
Cheers,
Paulo
On 06/28/2012 02:35 PM, Sebastiano Lora wrote:
> Hello,
> I do not know how to solve your problem (I had the same but under
> windows same time ago), but you can try to install the sextante plugin
> for QGIS. This should allow you to use R direct in QGIS.
> Hope it works
> bye
> Sebastiano
> On 28 June 2012 13:36, Paulo van Breugel <p.vanbreugel at gmail.com
> <mailto:p.vanbreugel at gmail.com>> wrote:
> Sorry, I should have mentioned that I am working with QGIS master
> on Ubuntu 12.04, manageR 1.0 and R 2.15
> On 06/28/2012 01:34 PM, Paulo van Breugel wrote:
>> Hi,
>> I am trying to import a vector layer (shapefile) from QGIS in R
>> using manageR
>> First manageR does not find the sp package. That can be solved by
>> defining the library location
>> (library(sp,lib.loc="/home/paulo/.Rpackages/"). Not sure though
>> why manageR does not find the package by default, in R or Rstudio
>> this is no problem.
>> Then, when trying to import the layer (ctrl+L or the import
>> button) I am getting the following error message:
>> > manageR import function
>> Error in function (projargs) :
>> PROJ4 argument-value pairs must begin with +: NA
>> The vector layer is just a normal shapefile with prj file.
>> Best wishes
>> Paulo
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> Sebastiano Lora Dr phil
> Deutsches Archäologische Institut Orient-Abteilung
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120628/b5f41a0b/attachment.html>
