[Qgis-user] Problems to open older project
William Kyngesburye
woklist at kyngchaos.com
Fri Jun 29 09:14:58 PDT 2012
Hmm, I guess disabling a plugin does not disable the provider component, still crashing on a delimited text layer.
I don't know where to go with this, taking it back to the mailing list...
crash snippet:
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libdelimitedtextprovider.so 0x0000000119012eaf QgsDelimitedTextProvider::~QgsDelimitedTextProvider() + 35
1 libdelimitedtextprovider.so 0x0000000119012e62 QgsDelimitedTextProvider::~QgsDelimitedTextProvider() + 18
2 org.qgis.qgis_core 0x0000000103e2d5b4 QgsProviderRegistry::provider(QString const&, QString const&) + 192
3 org.qgis.qgis_core 0x0000000103e50e2b QgsVectorLayer::setDataProvider(QString const&) + 89
4 org.qgis.qgis_core 0x0000000103e5b825 QgsVectorLayer::readXml(QDomNode const&) + 463
5 org.qgis.qgis_core 0x0000000103dfc763 QgsMapLayer::readXML(QDomNode const&) + 3999
6 org.qgis.qgis_core 0x0000000103e1e815 QgsProject::addLayer(QDomElement const&, QList<QDomNode>&, QList<QPair<QgsVectorLayer*, QDomElement> >&) + 1291
7 org.qgis.qgis_core 0x0000000103e1c910 QgsProject::_getMapLayers(QDomDocument const&) + 1378
8 org.qgis.qgis_core 0x0000000103e1f908 QgsProject::read() + 3760
9 org.qgis.qgis 0x0000000100023cd0 QgisApp::fileOpen() + 616
10 org.qgis.qgis 0x0000000100249257 QgisApp::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) + 4747
On Jun 29, 2012, at 10:03 AM, José Carlos Guerrero Antúnez wrote:
> Hi,
> I updated GDAL MrSID plugin, GeoPDF Plugin and disabling the delimited text before loading the project.
> I still have the same problem (attached QGIS report crash).
> Regards,
> Jose Carlos Guerrero
> 2012/6/28 William Kyngesburye <kyngchaos at kyngchaos.com>
> That got most of it clean, there is still a reference to an old framework. Maybe from the GDAL MrSID plugin, maybe from the GDAL GeoPDF plugin.
> Still crashing in the delimited text plugin. Do you have delimited text (ie csv) layers in this project (and not in the others that opened)? You could try disabling the delimited text plugin before loading the project.
> P.S. crash reports in PDF form are hard to read. If you ignore the crash and open Console.app, you can attach plain text crash logs (Diagnotic Reports) directly to a new email from the File menu. ^_^
> On Jun 28, 2012, at 4:04 PM, José Carlos Guerrero Antúnez wrote:
> > Hi William,
> > I followed your instruction, and I updated all frameworks, python module and qgis but I can't open this project (attached file with the report qgis).
> > In contrast, other older project I can open and sometime it showme "Handle bad layers" and then I browse the layers without problem and the project is opened correctly.
> > Many thanks again,
> > 2012/6/28 William Kyngesburye <woklist at kyngchaos.com>
> > A few things I see that might be a problem:
> > It looks like you might have an old matplotlib (it's getting loaded by a QGIS plugin). I updated that after the Big Update.
> > Old builtin QGIS plugins are loaded. These usually cause QGIS to crash immediately. Delete the QGIS.app and reinstall.
> > It's crashing in the delimited text plugin/provider. Take care of the above things and see if it works.
> > On Jun 28, 2012, at 10:41 AM, José Carlos Guerrero Antúnez wrote:
> > > I don't remember well but I think the answer is not. I attached pdf files in the order of the tasks performed.
> > > Regards,
> > <Report_qgis_crash.pdf>
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
> <QGIS_2012-06-29-115940_iMac-de-Jose-Carlos-Guerrero-Antunez-5.crash>
"Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life."
- Marvin
