[Qgis-user] Re: Export map to graphics program (Gerhardus Geldenhuis)
Chris Henrick
chrishenrick at gmail.com
Tue Mar 6 09:25:13 PST 2012
I have successfully exported map layers from SVG to AI by exporting either
individual layers or a few layers at a time. I then open the layers up in
AI, ungroup them, deleted the boxes and clipping masks, and then line them
up manually using a layer I export each time as a reference. It's time
consuming but will work. I also found that either odd things happen, QGIS
crashes, or memory in AI gets bogged down when trying to export/open a
large SVG file.
Another option is using MaPublisher, but it has a hefty license fee. It's
basically a plug-in for AI. You could prep your data in QGIS and add your
final touches in AI by bringing the data in with Mapublisher.
-Chris
On Tue, Mar 6, 2012 at 4:20 AM, <qgis-user-request at lists.osgeo.org> wrote:
> Send Qgis-user mailing list submissions to
> qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
> 1. Re: AW: [Qgis-user] Labeling area (Zirneklitis)
> 2. raster clipper tool in qgis 1.7.4 (Tilottama Ghosh)
> 3. Re: GPS-Measure (Ramon Andi?ach)
> 4. Export map to graphics program (Gerhardus Geldenhuis)
> 5. Re: Actions HowTo (denisq at free.fr)
> 6. Re: Actions HowTo (Nathan Woodrow)
> 7. Re: Actions HowTo (Giuseppe Sucameli)
> 8. Re: GPS-Measure (Giovanni Manghi)
> Message: 1
> Date: Tue, 06 Mar 2012 10:53:13 +0200
> From: Zirneklitis <eko at lanet.lv>
> Subject: Re: AW: [Qgis-user] Labeling area
> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Message-ID: <4F55D079.5010903 at lanet.lv>
> Content-Type: text/plain; charset=windows-1252; format=flowed
> 1. Make visible View / Toolbars / Labels
> 2. Click on Labeling button in the toolbar
> 3. There is a button [...] at the end of Label this layer with.
> K.
> Starke Holger, Mag. wrote:
> > .. I didn´t found any
> > „expression-based-labeling“ in 1.7.4 also. Where can I find this feature?
> Message: 2
> Date: Tue, 6 Mar 2012 14:32:23 +0530
> From: Tilottama Ghosh <waggymaggy at gmail.com>
> Subject: [Qgis-user] raster clipper tool in qgis 1.7.4
> To: qgis-user <qgis-user at lists.osgeo.org>
> Message-ID:
> <CAAztfO=90b2VzGqP2DvAwn0kuxLf4NtsHRBRwNasQoEhXXFuvQ at mail.gmail.com
> Content-Type: text/plain; charset="iso-8859-1"
> Hi all,
> I just tested the raster clipper tool in the newly released qgis 1.7.4
> and it works now without giving the python script error. However, it still
> produces the shifted image. I hope the gdal developers fix that soon.
> This problem seems to exist only in gdal 1.8 and above. Is there any link
> from where I can download gdal 1.7 and plug it in qgis 1.7.4?
> Thanks!
> Tilottama
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20120306/47234a5f/attachment-0001.html
> Message: 3
> Date: Tue, 6 Mar 2012 17:26:47 +0800
> From: Ramon Andi?ach <custard at westnet.com.au>
> Subject: Re: [Qgis-user] GPS-Measure
> Message-ID: <773CE107-6043-457A-8E2D-C99BCEEA75F4 at westnet.com.au>
> Content-Type: text/plain; charset=iso-8859-1
> On 06/03/2012, at 15:14 , Starke Holger, Mag. wrote:
> > Hello,
> > I´m searching fort a possibility to measure areas using Live-GPS-Tracked
> vertices. After adding the feature the Area should be displayed and the
> label should be the measured area. Is it possible to combine the
> GPS-Tracking Tool with the area measuring tool?
> > Holger
> I'm not sure I understand correctly. It sounds like you're trying to
> measure the area of a feature that all GIS programmes will understand as a
> line. Is that right?
> -ramon.
> Message: 4
> Date: Tue, 6 Mar 2012 11:15:46 +0000
> From: Gerhardus Geldenhuis <gerhardus.geldenhuis at gmail.com>
> Subject: [Qgis-user] Export map to graphics program
> To: qgis-user at lists.osgeo.org
> Message-ID:
> <CAATm_0pCsO4BQdoz3ZtGD3YsyTrcoJ0UQJ5Yxoyk5w-eak9bvg at mail.gmail.com
> Hi
> I have tried to use the python plugin to export my map as a svg. When it
> worked it was selective about which layers it exported and at the moment it
> crashes. I was wondering if there is another way of exporting an image or
> vector graphic of my map. I want to add final touches to my paper copy map
> in Illustrator and am at the moment considering doing a number of print
> screens and stitching it together.
> Regards
> URL:
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20120306/4a305f74/attachment-0001.html
> Message: 5
> Date: Tue, 6 Mar 2012 12:31:20 +0100 (CET)
> From: denisq at free.fr
> Subject: Re: [Qgis-user] Actions HowTo
> To: cavallini at faunalia.it
> Cc: qgis-user <qgis-user at lists.osgeo.org>
> Message-ID:
> 122654125.699044.1331033480785.JavaMail.root at zimbra63-e11.priv.proxad.net>
> Content-Type: text/plain; charset=utf-8
> Hi,
> Well, at the moment I am using QGIS within windows system (both French
> GUI). I tried to set up the following action :
> - open chrome
> - open the url
> http://ficheinfoterre.brgm.fr/InfoterreFiche/ficheBss.action?id=%indice
> Where indice is a field of the layer.
> So I tried diferent ways :
> C:/Program Files (x86)/Google/Chrome/Application/chrome.exe
> C:/Program\ Files\ (x86)/Google/Chrome/Application/chrome.exe
> chrome.exe
> ... and I always get the following popup window : Impossible to lunch
> command
> Is there any trick for that ?
> Thanks a lot.
> Denis
> ----- Mail original -----
> De: "Paolo Cavallini" <cavallini at faunalia.it>
> À: "qgis-user" <qgis-user at lists.osgeo.org>
> Envoyé: Jeudi 1 Mars 2012 10:22:51
> Objet: [Qgis-user] Actions HowTo
> Hi all.
> We are writing a short howto for the new actions. We would like to add
> some more
> complex example that the usual "open the browser with this argument",
> possibly using
> coordinates and functions. Ideas and suggestions welcome.
> All the best, and thanks.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Message: 6
> Date: Tue, 6 Mar 2012 21:38:12 +1000
> From: Nathan Woodrow <madmanwoo at gmail.com>
> To: denisq at free.fr
> Message-ID:
> <CAAi8Yg_7FpjD=f3VjW=twqhT9y+K=8JxbUDfKuvXO0FpKD=J4g at mail.gmail.com
> Denis,
> This is how I normally launch the default browser in windows using QGIS
> actions.
> cmd /c start URL
> if you want to launch Chrome, this might work
> cmd /c start "C:/Program Files (x86)/Google/Chrome/Application/chrome.exe"
> URL
> reference for cmd start http://ss64.com/nt/start.html
> - Nathan
> On Tue, Mar 6, 2012 at 9:31 PM, <denisq at free.fr> wrote:
> > Hi,
> > - open chrome
> > - open the url
> > chrome.exe
> > command
> > Thanks a lot.
> > Denis
> > Hi all.
> > some more
> > possibly using
> > www.faunalia.eu
> URL:
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20120306/4d53bd9f/attachment-0001.html
> Message: 7
> Date: Tue, 6 Mar 2012 12:41:18 +0100
> From: Giuseppe Sucameli <sucameli at faunalia.it>
> Message-ID:
> <CAA6k8-+d0VE65ZG4YbQKcOuR31oxqghQaHM5JtEWfKGx9LQM=g at mail.gmail.com
> Content-Type: text/plain; charset=ISO-8859-1
> Hi Denis,
> command
> what QGis version are you using?
> The syntax to put field's value into an action changed in QGis master.
> Regards.
> > Thanks a lot.
> > Denis
> > Hi all.
> some more
> possibly using
> > www.faunalia.eu
> Giuseppe Sucameli
> Message: 8
> Date: Tue, 06 Mar 2012 12:20:03 +0000
> From: Giovanni Manghi <giovanni.manghi at faunalia.pt>
> To: "Starke Holger, Mag." <Starke at hagel.at>
> Cc: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Message-ID: <1331036403.2214.6.camel at sibirica>
> Content-Type: text/plain; charset="UTF-8"
> Hi,
> if the layer you are editing is Postgis you can use a trigger. Have a
> look here:
> http://ubuntuone.com/3u7v7E6nxg2JaAwXAAGbb8
> cheers
> -- Giovanni --
> On Tue, 2012-03-06 at 08:14 +0100, Starke Holger, Mag. wrote:
> > Hello,
> > Live-GPS-Tracked vertices. After adding the feature the Area should be
> > displayed and the label should be the measured area. Is it possible to
> > combine the GPS-Tracking Tool with the area measuring tool?
> > Holger
> > http://lists.osgeo.org/mailman/listinfo/qgis-usera
> End of Qgis-user Digest, Vol 73, Issue 16
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120306/cc9923ae/attachment.html>
