[Qgis-user] Export map to graphics program
Gerhardus Geldenhuis
gerhardus.geldenhuis at gmail.com
Tue Mar 6 09:32:06 PST 2012
Hi
I believe so but to be honest I think I introduced some kind of complexity
into my map which the plugin is not liking. It was thus working in 1.7.4
Regards
On 6 March 2012 17:29, Alex Mandel <tech_dev at wildintellect.com> wrote:
> Thanks for the additional information, I'll try to pass it on to the
> developer of the plugin.
> Was it working in 1.7.3?
> Thanks,
> Alex
> On 03/06/2012 09:24 AM, Gerhardus Geldenhuis wrote:
> > Hi
> > Confirming that I am using SimpleSVG
> > Some more details here is the error message when it fails:
> > http://pastebin.com/uPbVR08h.
> > When it was still working it would not for example show my spatialite
> > layers data. With the current version of my map it simply does not work.
> I
> > have restarted QGIS and restarted my laptop but to no avail. I am using
> > Ubuntu 11.04 and QGIS 1.7.4
> > My map currently has 6 layers that is visible and they are vector and
> > spatialite layers.
> > Regards
> > On 6 March 2012 17:18, Alex Mandel <tech_dev at wildintellect.com> wrote:
> >> On 03/06/2012 03:15 AM, Gerhardus Geldenhuis wrote:
> >>> Hi
> >>> I have tried to use the python plugin to export my map as a svg. When
> it
> >>> worked it was selective about which layers it exported and at the
> moment
> >> it
> >>> crashes. I was wondering if there is another way of exporting an image
> or
> >>> vector graphic of my map. I want to add final touches to my paper copy
> >> map
> >>> in Illustrator and am at the moment considering doing a number of print
> >>> screens and stitching it together.
> >>> Regards
> >> In addition to the SimpleSVG plugin (I assume thats the one you are
> >> trying to use), you can save a pdf or svg from the map composer it just
> >> tends to come out with some extra stuff.
> >> Could you please post more about the error you get? Do you get a message
> >> or the output just isn't what you expect? How many layers, what type?
> >> Does it fail on even simple exports or just complex ones?
> >> Thanks,
> >> Alex
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120306/6ebf3362/attachment.html>
