[Qgis-user] Export map to graphics program
Alex Mandel
tech_dev at wildintellect.com
Tue Mar 6 09:36:05 PST 2012
Are all layer using New Symbology and New Labelling (The one not in the
properties dialog)?
If not could you try only using those, and vice versa only using the old
symbology and old labelling?
Thanks,
Alex
On 03/06/2012 09:32 AM, Gerhardus Geldenhuis wrote:
> Hi
> I believe so but to be honest I think I introduced some kind of complexity
> into my map which the plugin is not liking. It was thus working in 1.7.4
> Regards
> On 6 March 2012 17:29, Alex Mandel <tech_dev at wildintellect.com> wrote:
>> Thanks for the additional information, I'll try to pass it on to the
>> developer of the plugin.
>> Was it working in 1.7.3?
>> Thanks,
>> Alex
>> On 03/06/2012 09:24 AM, Gerhardus Geldenhuis wrote:
>>> Hi
>>> Confirming that I am using SimpleSVG
>>> Some more details here is the error message when it fails:
>>> http://pastebin.com/uPbVR08h.
>>> When it was still working it would not for example show my spatialite
>>> layers data. With the current version of my map it simply does not work.
>> I
>>> have restarted QGIS and restarted my laptop but to no avail. I am using
>>> Ubuntu 11.04 and QGIS 1.7.4
>>> My map currently has 6 layers that is visible and they are vector and
>>> spatialite layers.
>>> Regards
>>> On 6 March 2012 17:18, Alex Mandel <tech_dev at wildintellect.com> wrote:
>>>> On 03/06/2012 03:15 AM, Gerhardus Geldenhuis wrote:
>>>>> Hi
>>>>> I have tried to use the python plugin to export my map as a svg. When
>> it
>>>>> worked it was selective about which layers it exported and at the
>> moment
>>>> it
>>>>> crashes. I was wondering if there is another way of exporting an image
>> or
>>>>> vector graphic of my map. I want to add final touches to my paper copy
>>>> map
>>>>> in Illustrator and am at the moment considering doing a number of print
>>>>> screens and stitching it together.
>>>>> Regards
>>>> In addition to the SimpleSVG plugin (I assume thats the one you are
>>>> trying to use), you can save a pdf or svg from the map composer it just
>>>> tends to come out with some extra stuff.
>>>> Could you please post more about the error you get? Do you get a message
>>>> or the output just isn't what you expect? How many layers, what type?
>>>> Does it fail on even simple exports or just complex ones?
>>>> Thanks,
>>>> Alex
