[Qgis-user] Creation of GPX file fails
Laurence Béchet bechet.laurence at gmail.com
Wed Mar 7 01:14:10 PST 2012
Thank you for the suggestion.
I did the test and of course the gpx created is not good, with a list of
error messages (not right values, like:
Error at file
C:\[...]\xerces-c-3.1.1-x86-windows-vc-10.0\bin/newtiti.gpx, line 76,
char 54
   Message: value '1730878.68283692' must be less than maxExclusive
facet value '180.0'
If I start from an existing gpx file that passes the test (like created
with dnrgarmin or mapsource) and try to upload it within Qgis, when I
check the metadata of the layer property, the Layer Spatial Reference
System is not correct
*+proj=longlat *+datum=WGS84 +no_defs
If I upload in Qgis the same data created by dnrgarmin but under the
projected shapefile type, then the Layer Spatial Reference System is correct
*+proj=tmerc* +lat_0=0 +lon_0=173 +k=0.9996 +x_0=1600000 +y_0=10000000
+ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs
*It's the general same issue: how do I force Qgis when uploading or
saving data in gpx file to use the correct Spatial reference system
(+proj)?*
How do other users do? Because I don't see the point of this software if
i cannot send my data from Qgis to my gps ...
Thank you
On 6/03/2012 18:10, Zirneklitis wrote:
> Have You checked this:
> http://www.topografix.com/gpx_validation.asp
> Laurence Béchet wrote:
>> I spent hour on the web and seem to be the only one to have this
>> issue ...
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120307/c84eb795/attachment.html>
