[Qgis-user] GRASS 6.4.2 GUI broken in OS X Lion
Sergio Zárate
acac09 at gmail.com
Fri Mar 9 10:06:52 PST 2012
Hi all.
Using Qgis Master in Lion, updating to GRASS 6.4.2 caused it to be unable
to open the GUI, apparently due to incapacity for location setting problems:
Starting GRASS ...
File
"/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py", line
894, in <module>
GRASSStartUp = StartUp(0)
File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py",
line 7981, in __init__
self._BootstrapApp()
line 7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
File
865, in OnInit
StartUp = GRASSStartup()
File
57, in __init__
self.grassrc = self._readGisRC()
File
393, in _readGisRC
grassrc[key.strip()] = utils.DecodeString(val.strip())
File
"/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gui_modules/utils.py",
line 667, in DecodeString
enc = locale.getdefaultlocale()[1]
File
"/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/locale.py",
line 478, in getdefaultlocale
File
line 410, in _parse_localename
*ValueError: unknown locale: UTF-8*
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Hit RETURN to continue...
Before that, GRASS worked through Qgis, but if used alone the GUI crashed
when pointing to grassdata folder.
The system is located in Spanish, Mexico). In text mode, one is unable to
change to the grassdata directory the pointed directory being home, thus
unusable.
To make things totally wrong, after GRASS failure, Qgis 1.9.90-Alpha
(8ccaef7) crashes as do 1.9.90-Alpha (8ccaef7) and 1.7.0-3:
Process: QGIS [282]
Path: /Applications/QGIS-1.9.app/Contents/MacOS/QGIS
Identifier: org.qgis.qgis-dev
Version: 1.9.90 (1.9.90 [8ccaef7])
Code Type: X86-64 (Native)
Parent Process: launchd [140]
Date/Time: 2012-03-09 11:21:20.803 -0600
OS Version: Mac OS X 10.7.2 (11C74)
Report Version: 9
Interval Since Last Report: 53780 sec
Crashes Since Last Report: 58
Per-App Interval Since Last Report: 11994 sec
Per-App Crashes Since Last Report: 3
Anonymous UUID: EB8BF461-7E5D-483E-8A68-6C8025318E99
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
objc[282]: garbage collection is OFF
abort() called
terminate called throwing an exception
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff8d5e7ce2 __pthread_kill + 10
1 libsystem_c.dylib 0x00007fff872aa7d2 pthread_kill + 95
2 libsystem_c.dylib 0x00007fff8729ba7a abort + 143
3 libc++abi.dylib 0x00007fff879b27bc abort_message + 214
4 libc++abi.dylib 0x00007fff879affcf default_terminate() +
28
5 libobjc.A.dylib 0x00007fff856241cd _objc_terminate + 114
6 libc++abi.dylib 0x00007fff879b0001
safe_handler_caller(void (*)()) + 11
7 libc++abi.dylib 0x00007fff879b005c std::terminate() + 16
8 libc++abi.dylib 0x00007fff879b1152 __cxa_throw + 114
9 org.qgis.qgisgrass 0x000000010d51defb
QgsGrass::error_routine(char const*, int) + 127
10 libgrass_gis.dylib 0x000000010d53d43b vfprint_error + 170
11 libgrass_gis.dylib 0x000000010d53daf0 G_fatal_error + 141
12 libgrass_gis.dylib 0x000000010d54348b G__no_gisinit + 53
13 org.qgis.qgisgrass 0x000000010d513828 QgsGrass::init() + 174
14 libgrassplugin.so 0x000000010d31641b
QgsGrassPlugin::initGui() + 79
15 org.qgis.qgis-dev 0x0000000100141604
QgsPluginRegistry::loadCppPlugin(QString) + 1042
16 org.qgis.qgis-dev 0x000000010014286b
QgsPluginRegistry::restoreSessionPlugins(QString) + 699
17 org.qgis.qgis-dev 0x0000000100035c9f
QgisApp::QgisApp(QSplashScreen*, bool, QWidget*, QFlags<Qt::WindowType>) +
3447
18 org.qgis.qgis-dev 0x0000000100007efd main + 5194
19 org.qgis.qgis-dev 0x00000001000067a4 start + 52
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff8d5e87e6 kevent + 10
1 libdispatch.dylib 0x00007fff877555be _dispatch_mgr_invoke +
923
2 libdispatch.dylib 0x00007fff8775414e _dispatch_mgr_thread +
54
Thread 2:
0 libsystem_kernel.dylib 0x00007fff8d5e8192 __workq_kernreturn +
10
1 libsystem_c.dylib 0x00007fff872aa594 _pthread_wqthread + 758
2 libsystem_c.dylib 0x00007fff872abb85 start_wqthread + 13
Thread 3:
10
Thread 4:
10
Thread 5:
10
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x00007fff5fbfbff8
rdx: 0x0000000000000000
rdi: 0x0000000000001903 rsi: 0x0000000000000006 rbp: 0x00007fff5fbfc020
rsp: 0x00007fff5fbfbff8
r8: 0x00007fff75834fb8 r9: 0x0000000000000282 r10: 0x00007fff8d5e7d0a
r11: 0xffffff80002d8220
r12: 0x000000010d30f5df r13: 0x0000000000000000 r14: 0x00007fff75837960
r15: 0x00007fff5fbfc170
rip: 0x00007fff8d5e7ce2 rfl: 0x0000000000000246 cr2: 0x00000001002e6000
Logical CPU: 0
Reinstalling did not solve the issue ¿any suggestions, please?
Thanks,
Sergio
Dr. Sergio Zárate Pedroche
José María Arroyo 228
Col. 22 de octubre
Morelia, Michoacán
C.P. 58341
México
________________________
Teléfono: (443) 352-5307
Celular: (443) 438-6212
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120309/c9170d0c/attachment.html>
