[Qgis-user] GRASS 6.4.2 GUI broken in OS X Lion
William Kyngesburye
woklist at kyngchaos.com
Fri Mar 9 12:39:52 PST 2012
On Mar 9, 2012, at 12:06 PM, Sergio Zárate wrote:
> Hi all.
> Using Qgis Master in Lion, updating to GRASS 6.4.2 caused it to be unable to open the GUI, apparently due to incapacity for location setting problems:
> Starting GRASS ...
> Traceback (most recent call last):
> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py", line 894, in <module>
> GRASSStartUp = StartUp(0)
> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py", line 7981, in __init__
> self._BootstrapApp()
> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py", line 7555, in _BootstrapApp
> return _core_.PyApp__BootstrapApp(*args, **kwargs)
> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py", line 865, in OnInit
> StartUp = GRASSStartup()
> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py", line 57, in __init__
> self.grassrc = self._readGisRC()
> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py", line 393, in _readGisRC
> grassrc[key.strip()] = utils.DecodeString(val.strip())
> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gui_modules/utils.py", line 667, in DecodeString
> enc = locale.getdefaultlocale()[1]
> File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/locale.py", line 478, in getdefaultlocale
> File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/locale.py", line 410, in _parse_localename
> ValueError: unknown locale: UTF-8
> Error in GUI startup. If necessary, please
> report this error to the GRASS developers.
> Switching to text mode now.
> Hit RETURN to continue...
That looks like a problem I've seen in GRASS alone - the user's shell language setting has only the UTF-8 encoding but wxpython expects language.encoding. I haven't heard back from the user if any of my suggestions have helped.
> Before that, GRASS worked through Qgis, but if used alone the GUI crashed when pointing to grassdata folder.
> The system is located in Spanish, Mexico). In text mode, one is unable to change to the grassdata directory the pointed directory being home, thus unusable.
> To make things totally wrong, after GRASS failure, Qgis 1.9.90-Alpha (8ccaef7) crashes as do 1.9.90-Alpha (8ccaef7) and 1.7.0-3:
> Process: QGIS [282]
> Path: /Applications/QGIS-1.9.app/Contents/MacOS/QGIS
> Identifier: org.qgis.qgis-dev
> Version: 1.9.90 (1.9.90 [8ccaef7])
> Code Type: X86-64 (Native)
> Parent Process: launchd [140]
> Date/Time: 2012-03-09 11:21:20.803 -0600
> OS Version: Mac OS X 10.7.2 (11C74)
> Report Version: 9
> Interval Since Last Report: 53780 sec
> Crashes Since Last Report: 58
> Per-App Interval Since Last Report: 11994 sec
> Per-App Crashes Since Last Report: 3
> Anonymous UUID: EB8BF461-7E5D-483E-8A68-6C8025318E99
> Crashed Thread: 0 Dispatch queue: com.apple.main-thread
> Exception Type: EXC_CRASH (SIGABRT)
> Exception Codes: 0x0000000000000000, 0x0000000000000000
> Application Specific Information:
> objc[282]: garbage collection is OFF
> abort() called
> terminate called throwing an exception
> Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
> 0 libsystem_kernel.dylib 0x00007fff8d5e7ce2 __pthread_kill + 10
> 1 libsystem_c.dylib 0x00007fff872aa7d2 pthread_kill + 95
> 2 libsystem_c.dylib 0x00007fff8729ba7a abort + 143
> 3 libc++abi.dylib 0x00007fff879b27bc abort_message + 214
> 4 libc++abi.dylib 0x00007fff879affcf default_terminate() + 28
> 5 libobjc.A.dylib 0x00007fff856241cd _objc_terminate + 114
> 6 libc++abi.dylib 0x00007fff879b0001 safe_handler_caller(void (*)()) + 11
> 7 libc++abi.dylib 0x00007fff879b005c std::terminate() + 16
> 8 libc++abi.dylib 0x00007fff879b1152 __cxa_throw + 114
> 9 org.qgis.qgisgrass 0x000000010d51defb QgsGrass::error_routine(char const*, int) + 127
> 10 libgrass_gis.dylib 0x000000010d53d43b vfprint_error + 170
> 11 libgrass_gis.dylib 0x000000010d53daf0 G_fatal_error + 141
> 12 libgrass_gis.dylib 0x000000010d54348b G__no_gisinit + 53
> 13 org.qgis.qgisgrass 0x000000010d513828 QgsGrass::init() + 174
> 14 libgrassplugin.so 0x000000010d31641b QgsGrassPlugin::initGui() + 79
> 15 org.qgis.qgis-dev 0x0000000100141604 QgsPluginRegistry::loadCppPlugin(QString) + 1042
> 16 org.qgis.qgis-dev 0x000000010014286b QgsPluginRegistry::restoreSessionPlugins(QString) + 699
> 17 org.qgis.qgis-dev 0x0000000100035c9f QgisApp::QgisApp(QSplashScreen*, bool, QWidget*, QFlags<Qt::WindowType>) + 3447
> 18 org.qgis.qgis-dev 0x0000000100007efd main + 5194
> 19 org.qgis.qgis-dev 0x00000001000067a4 start + 52
> Reinstalling did not solve the issue ¿any suggestions, please?
> Thanks,
> Sergio
I don't know about this one. Does QGIS crash at startup, or when loading a GRASS layer?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
