[Qgis-user] qgis vs grass
Jake Maier
j.m at jmforestry.com
Sat Mar 10 17:14:51 PST 2012
I found it and there is even a forestry toolkit. Did you use it? Is it any
good, what does it do for you?
-----Original Message-----
Sent: Saturday, March 10, 2012 7:46 PM
To: Jake Maier
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] qgis vs grass
Use Table Manager (Qgis python plugin) to manage table (i.e. delete and add
columns). At the moment, it will save the new table into a new shapefile
(*.shp, *.dbf, etc).
Noli
On 3/11/12, Jake Maier <j.m at jmforestry.com> wrote:
> I try to delete some of the fields (columns) in the attribute table
> but the delete feature is grayed out weather I toggle editing mode on or
off.
> How can I delete a field?
> Jake
> From: Noli Sicad [mailto:nsicad at gmail.com]
> Sent: Saturday, March 10, 2012 6:59 PM
> To: Jake Maier
> To calculate area - (shapeflie file) in QGIS,
> Have a look on the Vector (menu)->Geometry Tools -> Export / Add
> geometry columns.
> You will get a new shapefile with area and perimetre columns
> Simple hack for acres;
> Open dbf file of that shapefiles in LibreOffice / OpenOffice add a new
> columns for arces and just just conversion from units to acres.
> I think you can add column as well in the attributes table and add the
> formula for conversion tor default unit to acres.
> Re: aerial photos, you can use georeference plugin (C++ plugin -
> standard /default installed by QGIS to georeference those photos. It
> easy and simple to do georeferencing in QGIS compare to MapInfo and
ArcMap.
> Noli
>> Thanks Noli,
>> That was exactly the advice I was hoping for.
>> I write forest management plan, and work with some biologists on
>> Natural Resources Inventories. I provide the mapping with a bit
>> forestry consulting as a sideline.
>> So I want to show drainage maps or vegetation maps (airphotos or
>> topomaps overlain with different shaded polygons).
>> One important future goal is to show particular stands depending on
>> information in the database. I also was hoping grass may provide
>> better ways to calculate area. I need English system, acres. I think
>> that is not provided in QGIS.
>> Jake
>> Sent: Saturday, March 10, 2012 6:06 PM
>> To: Jake Maier
>> Hi Jake,
>> If you are just new to QGIS, just use QGIS without Grass plug-in first.
>> Familiarize yourself with QGIS. Download and read QGIS manual.
>> You can always install the Grass plug-in later.
>> If you used ArcMap before and not ArcInfo, mostly like to you don't
>> need Grass at the moment. Most of QGIS users (including me) have a
>> little use of Grass until you want advance Geoprocessing which can
>> not do
> in QGIS.
>> BTW, sort of things you want to use QGIS for forestry application.
>> ( BTW,I am trying to use QGIS for forest management and Spatial
>> forest estate modelling.)
>> Noli
>>> I'm new to qgis. I used ArcMap before so I have some GIS experience.
>>> I have the grass plug-in installed. Should I try to setup the grass
>>> database right away and try to do everything within grass or should
>>> I first use just qgis without Grass until I get more familiar with it.
>>> Any pointers are very welcome.
>>> Thanks in advance
>>> Jake
