[Qgis-user] QGIS farm application
Viktor Kalén viktor.kalen at gmail.com
Thu Mar 15 02:53:01 PDT 2012
Must say this sounds very intresting! I like youre idea!
I have som experience of using PostGIS to QGIS and must say I'm
impressed (comming from an ESRI environment).
I don't hav any experience in SpatialLite, but maybye this is the way
to go for an easier start.
For PostGIS there are some really useful plugins for QGIS wich helps
in managing the database (maybye there are similar plugins for Spatial
Lite?)
The one I use the most is called PostGIS manager. Here you can upload
dbf tables to your database. I guess you can easaly export from
OpenOffice to dbf?
Good luck!
Viktor
Den 15 mars 2012 07:54 skrev Antonello Lobianco (not reply)
<blackhole at lobianco.org>:
> You may want to consider also this: http://www.regmas.org
> It calculates optimal decisions for farmers using the open source glpk
> optimisation library taking GIS and space explicitelly into  account.
> It is for research models, not for a single farm, but you may be interested
> in the code..
> Antonello
> Il giorno 13 marzo 2012 17:17, Walter Ludwick <wludwick at mac.com> ha scritto:
>> I am trying to manage operations on my farm in a more scientific way,
>> using QGIS as a tool for making more informed decisions.
>> This involves mapping of points (e.g. fencepost) lines (e.g. irrigation
>> tube) and polygons (e.g. grazing paddock) and all related data across time,
>> to show in a graphic way how present configuration of resources compares to
>> a snapshot at any point in time past (i.e. historical facts) or future (i.e.
>> planning scenarios).
>> I am using a spreadsheet (OpenOffice Calc) to record actual data values,
>> build history,, and project what-if scenarios. Presuming that QGIS is the
>> best tool for managing vectorial data about how these facts map onto the
>> ground, then what is the best way of integrating data from these two
>> applications, i wonder?
>> Being not so technically inclined, i am quite apprehensive about
>> introducing a RDBMS into the mix (i see the PostGIS layer option available,
>> and gather that this enables connection to a Postgres db, which i know can
>> host our spreadsheet data, but…)  Well: if this means there will be less
>> hassle about keeping data integrated between our GIS and our spreadsheets,
>> then i might bite the bullet and do it.  What do you think?
>> If anyone here has anything to recommend, or any relevant experience to
>> share, i would be very grateful to hear about it. Thanks for listening!
>> Yours, Walt
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Antonello Lobianco
> Spedito da un indirizzo non presenziato
