[Qgis-user] mmqgis on OSX
David Fawcett david.fawcett at gmail.com
Tue Mar 13 18:57:42 PDT 2012
I am running QGIS 1.9.90-Alpha  revison e13e45f  on OSX Snow Leopard
from William's installers at kyngchaos.com.
QGIS works great and seems to run faster than past versions.  I am
running into an issue with the mmqgis pluggin.  Maybe this dev build
is just not fresh enough.
I can successfully find and install the plugin.  When I select any of
the options from the pluggins>mmqgis menu, no dialogs appear.  I am
guessing that it is an issue with Qt.
Here is what I see in the console:
3/13/12 8:23:08.565 PM [0x0-0x15015].org.qgis.qgis-dev: Warning:
loading of qgis translation failed
[/Applications/QGIS-1.9.app/Contents/MacOS/../Resources/i18n//qgis_en_US]
3/13/12 8:23:08.566 PM [0x0-0x15015].org.qgis.qgis-dev: Warning:
loading of qt translation failed
[/Applications/QGIS-1.9.app/Contents/translations/qt_en_US]
3/13/12 8:23:14.069 PM [0x0-0x15015].org.qgis.qgis-dev: Warning:
QFSFileEngine::open: No file name specified
3/13/12 8:23:22.256 PM [0x0-0x15015].org.qgis.qgis-dev: Warning:
QHttp: empty path requested is invalid -- using '/'
3/13/12 8:27:12.413 PM [0x0-0x15015].org.qgis.qgis-dev: Warning:
Object::connect: No such signal QComboBox::textChanged( const QString&
Object::connect:  (sender name:   'cmbTheme')
Object::connect:  (receiver name: 'QgsOptionsBase')
Object::connect:  (sender name:   'cmbIconSize')
3/13/12 8:27:12.414 PM [0x0-0x15015].org.qgis.qgis-dev: Warning:
If anyone thinks that there is a clear issue that warrants a ticket,
let me know and I will file one.
Thanks,
David.
