[Qgis-user] Plugin to add a layer for each unique value in acolumn
Andreas Neumann a.neumann at carto.net
Thu Mar 15 07:32:33 PDT 2012
 Ok - so it seems like a reporting / map production problem.
 I am not sure if the "EasyPrint" or "Atlas" Plugin can help. EasyPrint
 allows to print each feature on a separate map. But it sounds like for
 your problem easy print would have to be extended to allow for maps per
 filter or using a group attribute.
 I am not sure if there is an out of the box solution for your problem
 with QGIS.
 For my own similar projects I set up a printing process using Apache
 FOP with XSL-FO and then use QGIS-server to print the map extents. I
 understand that this would be overkill/too much work to setup for you.
 Andreas
 On Thu, 15 Mar 2012 12:50:00 -0000, James Stott wrote:
> Hi Nathan/Andreas,
> I would happily use another method to deal with this but I haven’t
> managed to come up with one.
> My layer has site boundaries (20 of them) on it. I also have a layer
> with buffers for my sites in it. I have a buffer per site (20 sites)
> and these are from a PostGIS view as these alter whenever I change
> the
> site boundary. I would like to then add each site boundary and each
> buffer onto a map as a separate layer because:
> 1) I add the site boundary and the buffer to a group, then the users
> can then turn each one on and off as needed when looking at the
> project file in QGIS.
> 2) For map production (using composers) I have a composer per site. I
> lock the layers in the composer map item and then jpg all my maps at
> the end. To do this I need to have each buffer on a separate layer as
> otherwise it would show the other sites as they are quite close
> together.
> The only way I can think to do this at the moment is to add each
> layer 20 times, and then query it by each individual site.
> James
> James Stott BSc (Hons) MSc | Senior Professional
> Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
> T: 01225 445548 | M: -
> http://www.npaconsult.co.uk/
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Andreas
> Neumann
> Sent: 15 March 2012 12:10
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Plugin to add a layer for each unique value
> in acolumn
>  Hi James,
>  And why would you need that? Maybe there is another solution to your
>  problem with just one or fewer layers.
>  Andreas
>  On Thu, 15 Mar 2012 11:08:04 -0000, James Stott wrote:
>> I would like to add a layer for each unique value of a text column
>> in
>> a
>> table.
>> For example, if I have a column called type, and the values in it
>> were
>> tree, stone and plant I would like to add a layer for each type. So
>> in
>> this example I would have 3 layers.
>> I know there is a plugin called Shapefile Splitter that splits out
>> to
>> a
>> shapefile for each unique value, but I just want it to split to
>> layers
>> in QGIS.
>> James
>> http://www.npaconsult.co.uk/http://www.npaconsult.co.uk/about-news.asp
>> http://www.npaconsult.co.uk/terms.asp
>> This Electronic Transmission is intended only for the attention of
>> the addressee. It may contain privileged and confidential
>> information.
>> If you are not the person for whom it is intended, you must not
>> copy,
>> distribute or take any action in reliance on it. If you have
>> received
>> this electronic transmission in error please notify us immediately
>> by
>> telephone, delete the transmission and destroy any hard copies.
>> Nicholas Pearson Associates has used all reasonable efforts to
>> ensure
>> that this message and any attachments are free from viruses.
>> Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel:
>> +44 (0) 01225 445548, Fax: +44 (0) 01225 312387, Website:
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>  Andreas Neumann
>  Böschacherstrasse 10A
>  8624 Grüt (Gossau ZH)
>  Switzerland
> information.
> If you are not the person for whom it is intended, you must not copy,
> distribute or take any action in reliance on it. If you have received
> this electronic transmission in error please notify us immediately by
> Nicholas Pearson Associates has used all reasonable efforts to ensure
 Andreas Neumann
 Switzerland
