[Qgis-user] Plugin to add a layer for each unique value in acolumn
James Stott
James.Stott at npaconsult.co.uk
Thu Mar 15 05:50:00 PDT 2012
Hi Nathan/Andreas,
I would happily use another method to deal with this but I haven’t managed to come up with one.
My layer has site boundaries (20 of them) on it. I also have a layer with buffers for my sites in it. I have a buffer per site (20 sites) and these are from a PostGIS view as these alter whenever I change the site boundary. I would like to then add each site boundary and each buffer onto a map as a separate layer because:
1) I add the site boundary and the buffer to a group, then the users can then turn each one on and off as needed when looking at the project file in QGIS.
2) For map production (using composers) I have a composer per site. I lock the layers in the composer map item and then jpg all my maps at the end. To do this I need to have each buffer on a separate layer as otherwise it would show the other sites as they are quite close together.
The only way I can think to do this at the moment is to add each layer 20 times, and then query it by each individual site.
James
James Stott BSc (Hons) MSc | Senior Professional
Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
T: 01225 445548 | M: -
http://www.npaconsult.co.uk/
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Andreas Neumann
Sent: 15 March 2012 12:10
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Plugin to add a layer for each unique value in acolumn
Hi James,
And why would you need that? Maybe there is another solution to your
problem with just one or fewer layers.
Andreas
On Thu, 15 Mar 2012 11:08:04 -0000, James Stott wrote:
> I would like to add a layer for each unique value of a text column in
> a
> table.
> For example, if I have a column called type, and the values in it
> were
> tree, stone and plant I would like to add a layer for each type. So
> in
> this example I would have 3 layers.
> I know there is a plugin called Shapefile Splitter that splits out to
> a
> shapefile for each unique value, but I just want it to split to
> layers
> in QGIS.
> James
> http://www.npaconsult.co.uk/http://www.npaconsult.co.uk/about-news.asp
> http://www.npaconsult.co.uk/terms.asp
> This Electronic Transmission is intended only for the attention of
> the addressee. It may contain privileged and confidential
> information.
> If you are not the person for whom it is intended, you must not copy,
> distribute or take any action in reliance on it. If you have received
> this electronic transmission in error please notify us immediately by
> telephone, delete the transmission and destroy any hard copies.
> Nicholas Pearson Associates has used all reasonable efforts to ensure
> that this message and any attachments are free from viruses.
> Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel:
> +44 (0) 01225 445548, Fax: +44 (0) 01225 312387, Website:
> Qgis-user mailing list
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
This Electronic Transmission is intended only for the attention of the addressee. It may contain privileged and confidential information. If you are not the person for whom it is intended, you must not copy, distribute or take any action in reliance on it. If you have received this electronic transmission in error please notify us immediately by telephone, delete the transmission and destroy any hard copies.
Nicholas Pearson Associates has used all reasonable efforts to ensure that this message and any attachments are free from viruses.
Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44 (0) 01225 445548, Fax: +44 (0) 01225 312387, Website: http://www.npaconsult.co.uk/
