[Qgis-user] Plugin to add a layer for each unique value in a column
Andreas Neumann a.neumann at carto.net
Thu Mar 15 05:09:37 PDT 2012
 Hi James,
 And why would you need that? Maybe there is another solution to your
 problem with just one or fewer layers.
 Andreas
 On Thu, 15 Mar 2012 11:08:04 -0000, James Stott wrote:
> I would like to add a layer for each unique value of a text column in
> a
> table.
> For example, if I have a column called type, and the values in it
> were
> tree, stone and plant I would like to add a layer for each type. So
> in
> this example I would have 3 layers.
> I know there is a plugin called Shapefile Splitter that splits out to
> a
> shapefile for each unique value, but I just want it to split to
> layers
> in QGIS.
> James
> James Stott BSc (Hons) MSc | Senior Professional
> Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
> T: 01225 445548 | M: -
> http://www.npaconsult.co.uk/
> http://www.npaconsult.co.uk/http://www.npaconsult.co.uk/about-news.asp
> http://www.npaconsult.co.uk/terms.asp
> This Electronic Transmission is intended only for the attention of
> the addressee. It may contain privileged and confidential
> information.
> If you are not the person for whom it is intended, you must not copy,
> distribute or take any action in reliance on it. If you have received
> this electronic transmission in error please notify us immediately by
> telephone, delete the transmission and destroy any hard copies.
> Nicholas Pearson Associates has used all reasonable efforts to ensure
> that this message and any attachments are free from viruses.
> Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel:
> +44 (0) 01225 445548, Fax: +44 (0) 01225 312387, Website:
> Qgis-user mailing list
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
