[Qgis-user] trouble with projections
Lee
muellerl at gmail.com
Thu Mar 15 10:14:48 PDT 2012
Do you know what EPSG these files are supposed to be in as obtained? I
realize you would like to use them or reproject them to 3174, but what is
their native EPSG or CRS name?
all the best,
Lee Mueller
ISA Certified Arborist
Registered Forester #46043
On Thu, Mar 15, 2012 at 1:10 PM, Kirk Wythers <kirk.wythers at gmail.com>wrote:
> I am having trouble with the crs of a particular project which contains 3
> shape file layers. I have two layers with display properly relative to each
> other, however, I am dubious that the crs is correct, since they are lat
> long yet the scale bar is displaying meters. I have another shape file,
> that when read into qgis, does not display properly at all.
> I have tried turning off "on the fly" projections, loading one layer, then
> turning on "on the fly" for the other layers. I have also tried manually
> setting the project crs with to one of the layers. I have also tried
> manually setting the crs of each layer to EPSG 3174 (Great Lakes Albers).
> None of these approaches seems to have any effect on the problem.
> Ideally I would like all files to be EPSG 3174 with units of degrees as
> Lat Long. Any suggestions on how I should be approaching this? Thanks in
> advance.
> Here is the crs metadata for each file:
> FILE 1:
> Storage type of this layer: ESRI Shapefile
> Source for this layer:
> /Users/kirkw/Desktop/latlong/meanNH4_2002.2006CLIP.shp
> Geometry type of the features in this layer: Polygon
> The number of features in this layer: 2093
> Editing capabilities of this layer: Add Features, Delete Features,
> Change Attribute Values, Add Attributes, Create Spatial Index, Fast Access
> to Features at ID, Change Geometries
> Extents:
> In layer spatial reference system units : xMin,yMin -95.917,43.0309 :
> xMax,yMax -83.2767,49.3746
> Layer Spatial Reference System:
> +proj=aea +lat_1=42.122774 +lat_2=49.01518 +lat_0=45.568977
> +lon_0=-84.455955 +x_0=1000000 +y_0=1000000 +ellps=GRS80
> +towgs84=0,0,0,0,0,0,0 +units=m +no_defs
> FILE 2:
> /Users/kirkw/Desktop/disturbance/reservelands/national_parks_boundaries_BTS_2006/national_parks_boundaries_BTS_2006.shp
> The number of features in this layer: 555
> Extents:
> In layer spatial reference system units : xMin,yMin -167.535,18.4641 :
> xMax,yMax -66.1064,68.6554
> FILE 3:
> /Users/kirkw/Desktop/disturbance/reservelands/Wilderness_Areas/Wilderness_Areas_12.1.11.shp
> The number of features in this layer: 794
> Extents:
> -19942895.95,2066644.91 : xMax,yMax 20012095.73,11022781.37
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120315/c53bff36/attachment.html>
