[Qgis-user] QGIS access via shellscript
Paulo van Breugel
p.vanbreugel at gmail.com
Sat Mar 17 03:43:40 PDT 2012
Maybe not a direct answer to your question, but did you check out this
page: http://grass.osgeo.org/wiki/TIN?
Also, there is a GRASS add-on r.refine that, and I quote, "reduces a DEM to
a TIN (takes as input a grid DEM and an error margin and simplifies it to
the desired accuracy into a TIN) ". I never used it myself, but you can
check it out on the GRASS wiki add-on page (
http://grass.osgeo.org/wiki/GRASS_AddOns)
Cheers,
Paulo
On Thu, Mar 15, 2012 at 2:42 PM, TheGeographer <dalura86 at googlemail.com>wrote:
> Hi,
> is there a chance to access QGIS via shellscript to automate GIS
> operations?
> With GRASS i can do it, but i need an automated TIN generation and under
> GRASS there's actually no module available which can create TINs.
> Greetings
> http://osgeo-org.1560.n6.nabble.com/QGIS-access-via-shellscript-tp4621383p4621383.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120317/05609803/attachment.html>
