I suppose, that "Polynomial 1" is linear transformation which preserves straight lines. Four points are too few :( By the way – these four points should be as far into the raster-map corners as possible. K. T. Gray Shaw wrote: > Oh sorry, that was Polynomial 1, using only four GCPs. I'd have used > Polynomial 2 but it was hard to find matching points. > >..
