[Qgis-user] Annoying CRS-Problem with EPSG 31468 / 2167
Ramon Andiñach custard at westnet.com.au
Wed Mar 21 14:22:04 PDT 2012
Hi there,
It could be a .prj file problem, apparently arc can sometimes write .prj without a TOWGS84 tag, which confuses OGR, and hence confuses QGIS. For instance see: http://lists.osgeo.org/pipermail/qgis-user/2012-March/015993.html
In master, OGR has been compiled to take a best guess and appropriate EPSG.
In the meantime, on of the settings that I change straight up on my QGIS installs is Settings -> Options -> CRS tab -> "Prompt for CRS"
Which makes QGIS ask if it's not sure what the projection for a layer is.
Hope that is of some help.
-ramon.
On 22/03/2012, at 24:07 , Bernd Vogelgesang wrote:
> Hi there,
> in Germany, we still quite often have Gauss-Krüger 4 projection for the source data from clients, formerly edited with ArcGIS.
> QGIS obviously has some problems with GK4 (EPSG:31468)
> When i import a shape with a .prj-file from ArcGIS, it doesn't promt for the crs, but immediately loads the shape.
> The tricky think is: if you do not check the crs manually every time, you run into chaos, cause QGIS always sets the crs to "Pulkovo 1942(83) / Gauss Krueger zone 4 (deprecated)" (EPSG:2167) which has quite an offset to the other crs.
> I'm quite confident that it's not a problem of the prj-file from ArcGIS, cause when i import a GK4-Layer into GRASS, there set the crs to GK4 as well, do my stuff and then send it back the result to QGIS, there the former EPSG 31468-Layer again is set to EPSG 2167 too !!!
> Has anyone an idea how to prevent this or what's the reason for this?
> It's really annoying and quite hard to explain to clients to check everytime the crs when they load a layer file.
> Greetz
> Bernd
