[Qgis-user] How to "uninstall\purge" QGIS in Windows
Alexandre Neto senhor.neto at gmail.com
Thu Mar 22 08:32:53 PDT 2012
Thanks you, it worked!
(And Union is working again)
On Thu, Mar 22, 2012 at 3:01 PM, G. Allegri <giohappy at gmail.com> wrote:
> You should check that the C:\Users\<username>\.qgis folder was deleted too,
> otherwise the previous settings and plugins will be kept.
> giovanni
> 2012/3/22 Anita Graser <anitagraser at gmx.at>
>> Those settings are stored in registry
>> HKEY_CURRENT_USER\Software\QuantumGIS
>> You can delete the registry entries to reset everything.
>> Regards,
>> Anita
>> On Thu, Mar 22, 2012 at 3:31 PM, Alexandre Neto <senhor.neto at gmail.com>
>> wrote:
>>> I'm having problems with my installed version of Quantum GIS (Union
>>> does not work) in windows. I came to understand that its probably
>>> something about my installation. And that developer version of QGIS
>>> will work correctly.
>>> So, I wanted to fully uninstall QGIS (previously installed by
>>> osgeo4w). I have uninstalled all software, and erased the OSGEO
>>> folder. But when I install the sofware, alll my installed plugins are
>>> still there, and the union is still not working in the new installed
>>> QGIS (1.9.90).
>>> So, how can I fully uninstall QGIS?
>>> Thanks!
>>> Alexandre Neto
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
