[Qgis-user] Re: Annoying CRS-Problem with EPSG 31468 / 2167: Conclusions?
Etienne Tourigny
etourigny.dev at gmail.com
Fri Mar 23 05:32:36 PDT 2012
On Fri, Mar 23, 2012 at 5:26 AM, <bernhard.stroebl at jena.de> wrote:
> I just tested with current trunk (compiled on OpenSUSE 64bit):
> When I load
> PROJCS["Transverse_Mercator",GEOGCS["GCS_bessel",DATUM["D_Deutsches_Hauptdreiecksnetz",SPHEROID["Bessel_1841",6377397.155,299.1528128]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",12],PARAMETER["scale_factor",1],PARAMETER["false_easting",4500000],PARAMETER["false_northing",0],UNIT["Meter",1]]
> which is EPSG:31468 (proj4 params in QGIS: +proj=tmerc +lat_0=0 +lon_0=12
> +k=1 +x_0=4500000 +y_0=0 +ellps=bessel
> +towgs84=582,105,414,1.04,0.35,-3.08,8.3 +units=m +no_defs)
> QGIS creates a user-defined srs:
> +proj=tmerc +lat_0=0 +lon_0=12 +k=1 +x_0=4500000 +y_0=0 +ellps=bessel
> +towgs84=598.1,73.7,418.2,0.202,0.045,-2.455,6.7 +units=m +no_defs
> although there is a difference in towgs84 params the layer matches a
> corresponding PostGIS layer defined with EPSG:31468 (I am aware there exist
> different towgs84-parameter sets for this datum)
> Same happens when saving as shape file from QGIS deleting the qpj file and
> then reloading into QGIS, so QGIS is not able to correctly interpret its own
> prj file!
> The only way I found to get the shape file loaded as EPSG:31468 is
> appending >>AUTHORITY["EPSG","31468"]<< to the prj file
> PostGIS' spatial_ref_sys table contains the prj string (field srtext) and
> the proj4 params (field proj4text) for the projection
> srtext: PROJCS["DHDN / 3-degree Gauss-Kruger zone
> 4",GEOGCS["DHDN",DATUM["Deutsches_Hauptdreiecksnetz",SPHEROID["Bessel
> 1841",6377397.155,299.1528128,AUTHORITY["EPSG","7004"]],AUTHORITY["EPSG","6314"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4314"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",12],PARAMETER["scale_factor",1],PARAMETER["false_easting",4500000],PARAMETER["false_northing",0],AUTHORITY["EPSG","31468"],AXIS["Y",EAST],AXIS["X",NORTH]]
> proj4text: +proj=tmerc +lat_0=0 +lon_0=12 +k=1 +x_0=4500000 +y_0=0
> +ellps=bessel +datum=potsdam +units=m +no_defs
> remarks:
> 1) srtext contains >>AUTHORITY["EPSG","31468"]<<
> 2) proj4 says >>+datum=potsdam<< whereas srtext says
>>>DATUM["Deutsches_Hauptdreiecksnetz"<<
> What could help?
> Somehow QGIS needs to use _all_ information given in the prj file and find a
> matching srs(proj4 parameters) for that. If there are several matching the
> user should choose which to apply, if there is none matching create a
> user-defined srs with the parameters given but tell the user. Maybe the
> datum parameter should be added to the proj4 definition of the projection. I
> am aware that a +datum parameter is only a short for a +towgs84 parameter
> but the datum is the same for the projection whereas towgs84 may differ
> locally.
> Maybe in at most 5 years' time we won't need GAUSS-KRUEGER any more as we
> are supposed to be switched to ETRS89 by then ;-)
> Bernhard
> Am 22.03.2012 19:23, schrieb Etienne Tourigny:
>> The following only applies to builds using master (and upcoming 1.8)
>> and gdal-1.9
>> Jeff pushed in master the fix which add missing TOWGS84 parameters (by
>> using GDAL_FIX_ESRI_WKT=TOWGS84). It is possible that using
>> GDAL_FIX_ESRI_WKT=GEOGCS would resolve this issue. Perhaps we couls
>> add an option for this, and set the default to GEOGCS?
> how can I use this?
Berhard, this is already in Master and 1.8. Can you try setting
GDAL_FIX_ESRI_WKT=GEOGCS in qgsogrprovider.cpp?
You can also play with the command line and see what comes up.
GDAL_FIX_ESRI_WKT=GEOGCS gdalsrsinfo file.prj
GDAL_FIX_ESRI_WKT=TOWGS84 gdalsrsinfo file.prj
GDAL_FIX_ESRI_WKT=NO gdalsrsinfo file.prj
although in this case I am afraid that gdal/ogr sees it as
all the best,
Etienne
>> see bug http://hub.qgis.org/issues/5142
>> Is there a proper fix for this in 1.7.4?
>> Etienne
>> On Thu, Mar 22, 2012 at 12:35 PM,<bernhard.stroebl at jena.de> wrote:
>>> Am 22.03.2012 16:05, schrieb Bernd Vogelgesang:
>>>> So, the problem was now described thoroughly, but what are the
>>>> conclusions now?
>>> There is already a ticket open http://hub.qgis.org/issues/4977
>>> although I have no idea if the issue has been solved or not
>>>> I'm going to spread QGIS in my region in the next months, and it's quite
>>>> hard to explain to the people, who to 99% work with EPSG 31468-data,
>>>> that they can't ever rely on any data they produce and that they have to
>>>> double-check each layer after creation for the right CRS, even if they
>>>> set it correctly in each setting available?!?
>>>> I'm not too familiar with all those packages involved handling the CRSs,
>>>> so can someone please point me the way who to address with this problem?
>>>> For novice QGIS-users, this "bug" is a real exclusion criterion for QGIS
>>>> for they will only create crap with it!
>>>> Again my findings:
>>>> Options settings: new layers and projects are created with EPSG 31468,
>>>> promting for CRS ist set.
>>>> - EPSG 31468-Layers with a prj-file from ArcGIS get loaded as 2167
>>>> without promting for the CRS
>>>> - EPSG 31468-Layers loaded into a EPSG 31468-Region in GRASS are handed
>>>> back to QGIS as ... 2167
>>>> - New Layers created in some plugins (like some ftools-plugins), added
>>>> to the TOC, are in ... 2167 .. or even 3397
>>>> What can i do? (And i really wonder what all those other german users do
>>>> and why the don't complain...)
>>> For me the base of the problem seems to be that the prj file is not
>>> matched
>>> to the right EPSG srs. As soon as you tell the layer it is EPSG:31468 it
>>> is
>>> positioned correctly. So the problem arises only with shapefiles; at my
>>> work
>>> we use PostGIS for most of our data (that is of course no help for you
>>> but
>>> explains why I am not "complaining")
>>> Bernhard
>>>> Thanx for advice
>>>> Bernd
>>>> (QGIS 1.7.4, osgeo4w advanced install, Win7 64bit)
> ________ Information from NOD32 ________
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
