[Qgis-user] Re: Annoying CRS-Problem with EPSG 31468 / 2167: Conclusions?
bernhard.stroebl at jena.de bernhard.stroebl at jena.de
Sun Mar 25 23:42:02 PDT 2012
Am 23.03.2012 13:32, schrieb Etienne Tourigny:
> On Fri, Mar 23, 2012 at 5:26 AM,<bernhard.stroebl at jena.de>  wrote:
>> I just tested with current trunk (compiled on OpenSUSE 64bit):
>> When I load
>> PROJCS["Transverse_Mercator",GEOGCS["GCS_bessel",DATUM["D_Deutsches_Hauptdreiecksnetz",SPHEROID["Bessel_1841",6377397.155,299.1528128]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",12],PARAMETER["scale_factor",1],PARAMETER["false_easting",4500000],PARAMETER["false_northing",0],UNIT["Meter",1]]
>> which is EPSG:31468 (proj4 params in QGIS: +proj=tmerc +lat_0=0 +lon_0=12
>> +k=1 +x_0=4500000 +y_0=0 +ellps=bessel
>> +towgs84=582,105,414,1.04,0.35,-3.08,8.3 +units=m +no_defs)
>> QGIS creates a user-defined srs:
>> +proj=tmerc +lat_0=0 +lon_0=12 +k=1 +x_0=4500000 +y_0=0 +ellps=bessel
>> +towgs84=598.1,73.7,418.2,0.202,0.045,-2.455,6.7 +units=m +no_defs
>> although there is a difference in towgs84 params the layer matches a
>> corresponding PostGIS layer defined with EPSG:31468 (I am aware there exist
>> different towgs84-parameter sets for this datum)
>> Same happens when saving as shape file from QGIS deleting the qpj file and
>> then reloading into QGIS, so QGIS is not able to correctly interpret its own
>> prj file!
>> The only way I found to get the shape file loaded as EPSG:31468 is
>> appending>>AUTHORITY["EPSG","31468"]<<  to the prj file
>> PostGIS' spatial_ref_sys table contains the prj string (field srtext) and
>> the proj4 params (field proj4text) for the projection
>> srtext: PROJCS["DHDN / 3-degree Gauss-Kruger zone
>> 4",GEOGCS["DHDN",DATUM["Deutsches_Hauptdreiecksnetz",SPHEROID["Bessel
>> 1841",6377397.155,299.1528128,AUTHORITY["EPSG","7004"]],AUTHORITY["EPSG","6314"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4314"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",12],PARAMETER["scale_factor",1],PARAMETER["false_easting",4500000],PARAMETER["false_northing",0],AUTHORITY["EPSG","31468"],AXIS["Y",EAST],AXIS["X",NORTH]]
>> proj4text: +proj=tmerc +lat_0=0 +lon_0=12 +k=1 +x_0=4500000 +y_0=0
>> +ellps=bessel +datum=potsdam +units=m +no_defs
>> remarks:
>> 1) srtext contains>>AUTHORITY["EPSG","31468"]<<
>> 2) proj4 says>>+datum=potsdam<<  whereas srtext says
>>>> DATUM["Deutsches_Hauptdreiecksnetz"<<
>> What could help?
>> Somehow QGIS needs to use _all_ information given in the prj file and find a
>> matching srs(proj4 parameters) for that. If there are several matching the
>> user should choose which to apply, if there is none matching create a
>> user-defined srs with the parameters given but tell the user. Maybe the
>> datum parameter should be added to the proj4 definition of the projection. I
>> am aware that a +datum parameter is only a short for a +towgs84 parameter
>> but the datum is the same for the projection whereas towgs84 may differ
>> locally.
>> Maybe in at most 5 years' time we won't need GAUSS-KRUEGER any more as we
>> are supposed to be switched to ETRS89 by then ;-)
>> Bernhard
>> Am 22.03.2012 19:23, schrieb Etienne Tourigny:
>>> The following only applies to builds using master (and upcoming 1.8)
>>> and gdal-1.9
>>> Jeff pushed in master the fix which add missing TOWGS84 parameters (by
>>> using GDAL_FIX_ESRI_WKT=TOWGS84).  It is possible that using
>>> GDAL_FIX_ESRI_WKT=GEOGCS would resolve this issue.  Perhaps we couls
>>> add an option for this, and set the default to GEOGCS?
>> how can I use this?
> Berhard, this is already in Master and 1.8.  Can you try setting
> GDAL_FIX_ESRI_WKT=GEOGCS in qgsogrprovider.cpp?
Etienne,
thank you for your instructions
I replaced WGS84 in qgsogrprovider.cpp with GEOGCS (QGIS master)
result stays the same: User-defined srs with towgs84 params is applied
> You can also play with the command line and see what comes up.
> GDAL_FIX_ESRI_WKT=GEOGCS gdalsrsinfo file.prj
PROJ.4 : '+proj=tmerc +lat_0=0 +lon_0=12 +k=1 +x_0=4500000 +y_0=0
+ellps=bessel +towgs84=598.1,73.7,418.2,0.202,0.045,-2.455,6.7 +units=m
+no_defs '
> GDAL_FIX_ESRI_WKT=TOWGS84 gdalsrsinfo file.prj
+no_defs '
> GDAL_FIX_ESRI_WKT=NO gdalsrsinfo file.prj
+datum=potsdam +units=m +no_defs '
This would be my preferred parameters as datum=potsdam can be different
towgs84 parameters in different locations
However the problem persists that QGIS does not recognize the projection
as EPSG:31468 no matter if I set it to GEOGCS, TOWGS84 or NO!
Neiter does it detect the correct projction from the prj file QGIS
itself created.
Bernhard
> although in this case I am afraid that gdal/ogr sees it as
> all the best,
> Etienne
>>> see bug http://hub.qgis.org/issues/5142
>>> Is there a proper fix for this in 1.7.4?
>>> Etienne
>>> On Thu, Mar 22, 2012 at 12:35 PM,<bernhard.stroebl at jena.de>    wrote:
>>>> Am 22.03.2012 16:05, schrieb Bernd Vogelgesang:
>>>>> So, the problem was now described thoroughly, but what are the
>>>>> conclusions now?
>>>> There is already a ticket open http://hub.qgis.org/issues/4977
>>>> although I have no idea if the issue has been solved or not
>>>>> I'm going to spread QGIS in my region in the next months, and it's quite
>>>>> hard to explain to the people, who to 99% work with EPSG 31468-data,
>>>>> that they can't ever rely on any data they produce and that they have to
>>>>> double-check each layer after creation for the right CRS, even if they
>>>>> set it correctly in each setting available?!?
>>>>> I'm not too familiar with all those packages involved handling the CRSs,
>>>>> so can someone please point me the way who to address with this problem?
>>>>> For novice QGIS-users, this "bug" is a real exclusion criterion for QGIS
>>>>> for they will only create crap with it!
>>>>> Again my findings:
>>>>> Options settings: new layers and projects are created with EPSG 31468,
>>>>> promting for CRS ist set.
>>>>> - EPSG 31468-Layers with a prj-file from ArcGIS get loaded as 2167
>>>>> without promting for the CRS
>>>>> - EPSG 31468-Layers loaded into a EPSG 31468-Region in GRASS are handed
>>>>> back to QGIS as ... 2167
>>>>> - New Layers created in some plugins (like some ftools-plugins), added
>>>>> to the TOC, are in ... 2167 .. or even 3397
>>>>> What can i do? (And i really wonder what all those other german users do
>>>>> and why the don't complain...)
>>>> For me the base of the problem seems to be that the prj file is not
>>>> matched
>>>> to the right EPSG srs. As soon as you tell the layer it is EPSG:31468 it
>>>> is
>>>> positioned correctly. So the problem arises only with shapefiles; at my
>>>> work
>>>> we use PostGIS for most of our data (that is of course no help for you
>>>> but
>>>> explains why I am not "complaining")
>>>> Bernhard
>>>>> Thanx for advice
>>>>> Bernd
>>>>> (QGIS 1.7.4, osgeo4w advanced install, Win7 64bit)
>> ________ Information from NOD32 ________
>> This message was checked by NOD32 Antivirus System for Linux Mail Server.
>> http://www.nod32.com
Bernhard Ströbl
Anwendungsbetreuer GIS
Kommunale Immobilien Jena
Am Anger 26
07743 Jena
Tel.: 03641 49- 5190
E-Mail: bernhard.stroebl at jena.de
Internet: www.kij.de
Eigenbetrieb der Stadt Jena
Werkleiter: Thomas Dirkes
