[Qgis-user] Problem with interpolation plugin
Zara Teixeira zarafani at gmail.com
Fri Mar 23 08:14:55 PDT 2012
I have this shapefile with points in ESRI:
102164<http://spatialreference.org/ref/esri/102164/>
Because all my work is in EPSG 3763, I changed the CRS to this one.
 The problem is that everytime I try to create a TIN with the interpolation
plugin, both QGIS 1.9.9 and 1.7.4 crash. I have them installed in Windows 7.
This doesn't happen with the original shapefile, or even if I use the IDW
algorithm, but happens if I transform the shapefile to any other CRS.
P.S. I would prefer to change the CRS before I interpolate.
Any idea why?
Thanks in advance.
Zara
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120323/90219ce6/attachment.html>
