[Qgis-user] Problem with interpolation plugin
Giovanni Manghi
giovanni.manghi at faunalia.pt
Fri Mar 23 12:16:27 PDT 2012
Hi Zara,
can you please send a me sample (that causes the error) to allow do some
tests?
thanks
-- Giovanni --
On Fri, 2012-03-23 at 15:14 +0000, Zara Teixeira wrote:
> Hi,
> I have this shapefile with points in ESRI: 102164
> Because all my work is in EPSG 3763, I changed the CRS to this one.
> The problem is that everytime I try to create a TIN with the
> interpolation plugin, both QGIS 1.9.9 and 1.7.4 crash. I have them
> installed in Windows 7.
> This doesn't happen with the original shapefile, or even if I use the
> IDW algorithm, but happens if I transform the shapefile to any other
> CRS.
> P.S. I would prefer to change the CRS before I interpolate.
> Any idea why?
> Thanks in advance.
> Zara
> Qgis-user mailing list
