[Qgis-user] Problem with interpolation plugin
Zara Teixeira
zarafani at gmail.com
Mon Mar 26 02:03:43 PDT 2012
Thanks Giovanni.
I'll wait for further developments.
Zara
On Mon, Mar 26, 2012 at 9:51 AM, Giovanni Manghi <
giovanni.manghi at faunalia.pt> wrote:
> Hi Zara,
> I tested your dataset, saving it to epsg 3763 and get the issue when
> doing the TIN interpolation (I will file a ticket). IDW works fine here,
> as also any method in the "raster -> analysis -> grid" tool.
> cheers
> -- Giovanni --
> On Fri, 2012-03-23 at 16:01 +0000, Zara Teixeira wrote:
> > It is in fact the 20790, and I had tried that too.
> > But the problem remains if I convert it to another CRS.
> > thanks anyway.
> > On Fri, Mar 23, 2012 at 3:48 PM, ALT SHN <i.geografica at alt-shn.org>
> > wrote:
> > It seems to be a CRS problem.
> > First you have to be sure what EPSG code is equivalent to ESRI
> > 102164 (I think it's the 20790)
> > Before converting to 3763, make sure the layer assumes the
> > correct EPSG code as CRS. Go to Properties --> General and
> > then declare 20790 as the correct EPSG, Then Save it as 3763.
> > Hope it helps
> > 2012/3/23 Zara Teixeira <zarafani at gmail.com>
> > Hi,
> > I have this shapefile with points in ESRI: 102164
> > Because all my work is in EPSG 3763, I changed the CRS
> > to this one.
> > The problem is that everytime I try to create a TIN
> > with the interpolation plugin, both QGIS 1.9.9 and
> > 1.7.4 crash. I have them installed in Windows 7.
> > This doesn't happen with the original shapefile, or
> > even if I use the IDW algorithm, but happens if I
> > transform the shapefile to any other CRS.
> > P.S. I would prefer to change the CRS before I
> > interpolate.
> > Any idea why?
> > Thanks in advance.
> > Zara
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Associação Leonel Trindade
> > SOCIEDADE DE HISTÓRIA NATURAL
> > Apartado 25 2564-909 Torres Vedras Portugal
> > Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560
> > Torres Vedras
> > Laboratório de Paleontologia e Paleoecologia: Polígono
> > Industrial do Alto do Ameal 2565-641 Ramalhal
> > http://alt-shn.blogspot.com
> > www.alt-shn.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120326/ba8a4f5a/attachment.html>
