[Qgis-user] SEXTANTE - problem using Merge from SAGA
Victor Olaya volayaf at gmail.com
Fri Mar 30 14:15:43 PDT 2012
> I stumbled across this problem, but Im not sure if Im doing everything
> right: I tried to use "Merge" from SAGA, selected 2 shapefiles, defined the
> output folder and when I tried to run the tool the following message
> appeared:
> "Could not load the layer C:/PATH/TO/FOLDER"
In order to know what is happening, could you please send me the log
file? It is located in [your user folder]/sextante/sextante_qgis.log
Also, you can go to the SEXTANTE history, and check in the INFO
branch. You should have two entries for each execution of the SAGA
algorithm, one with the SAGA commands used and another one with the
console output generated by SAGA. That might give you a clue of what
is happening
Are you using the "save to temporary layer" option, or entering a
filename directly?. If you are using a filename, is it relative or
absolute?
Regards
Victor
