[Qgis-user] Re: SEXTANTE - problem using Merge from SAGA
Filipe Silva Dias
filipesdias at gmail.com
Fri Mar 30 09:55:53 PDT 2012
Im using Windows 7 64bits and QGIS Master downloaded 1 hour ago.
On Fri, Mar 30, 2012 at 5:52 PM, Filipe Silva Dias <filipesdias at gmail.com>wrote:
> Hello Victor, thanks for bringing SEXTANTE to QGIS, I often need to do GIS
> analysis and this tool is going to very important for my work.
> I stumbled across this problem, but Im not sure if Im doing everything
> right: I tried to use "Merge" from SAGA, selected 2 shapefiles, defined the
> output folder and when I tried to run the tool the following message
> appeared:
> "Could not load the layer C:/PATH/TO/FOLDER"
> Thanks
> Filipe
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120330/1a197220/attachment.html>
