[Qgis-user] SEXTANTE - problem using Merge from SAGA
Filipe Silva Dias
filipesdias at gmail.com
Fri Mar 30 09:52:27 PDT 2012
Hello Victor, thanks for bringing SEXTANTE to QGIS, I often need to do GIS
analysis and this tool is going to very important for my work.
I stumbled across this problem, but Im not sure if Im doing everything
right: I tried to use "Merge" from SAGA, selected 2 shapefiles, defined the
output folder and when I tried to run the tool the following message
appeared:
"Could not load the layer C:/PATH/TO/FOLDER"
Thanks
Filipe
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120330/ca3378ce/attachment.html>
