[Qgis-user] Problems with gdal and hdf files
Agustin Lobo
alobolistas at gmail.com
Wed May 2 02:41:34 PDT 2012
Hi!
The gdal info of a multiband satellite image in hdf is reported by
gdal as "Size is 512, 512"
in contradiction with the size of the subdatasets. QGIS and R
(raster+rgdal) report an error at opening the file,
while envi and HDFLook can open it with no problem. I include the
gdalinfo output and the
info reported by HDFLook. Any help appreciated.
Thanks
Agus
$ gdalinfo --version
GDAL 1.8.0, released 2011/01/12
$ gdalinfo lndsr.L5169054_05420101216.hdf
Driver: HDF4/Hierarchical Data Format Release 4
Files: lndsr.L5169054_05420101216.hdf
Size is 512, 512
Coordinate System is `'
Metadata:
DataProvider=UMD
Satellite=LANDSAT_5
Instrument=TM
AcquisitionDate=2010-12-16T00:00:00.000000Z
Level1ProductionDate=2012-02-22T00:00:00.000000Z
SolarZenith=42.02009
SolarAzimuth=141.4236
WRS_System=2
WRS_Path=169
WRS_Row=54
NumberOfBands=6
BandNumbers=1, 2, 3, 4, 5, 7
ShortName=L5TSR
LocalGranuleID=L5TSR.a2010350.w2p169r054.020.2012117105207.hdf
ProductionDate=2012-04-26T10:52:07Z
PGEVersion=1.0.9
ProcessVersion=1.0.4
WestBoundingCoordinate=36.6199876177544
EastBoundingCoordinate=38.780676500528
NorthBoundingCoordinate=9.61826703329522
SouthBoundingCoordinate=7.72285510894074
OrientationAngle=0
PixelSize=30
HDFEOSVersion=HDFEOS_V2.4
Cloud Mask Algo Version=CMReflectanceBasedv1.0
Subdatasets:
SUBDATASET_1_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band1
SUBDATASET_1_DESC=[6961x7901] band1 Grid (16-bit integer)
SUBDATASET_2_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band2
SUBDATASET_2_DESC=[6961x7901] band2 Grid (16-bit integer)
SUBDATASET_3_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band3
SUBDATASET_3_DESC=[6961x7901] band3 Grid (16-bit integer)
SUBDATASET_4_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band4
SUBDATASET_4_DESC=[6961x7901] band4 Grid (16-bit integer)
SUBDATASET_5_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band5
SUBDATASET_5_DESC=[6961x7901] band5 Grid (16-bit integer)
SUBDATASET_6_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band7
SUBDATASET_6_DESC=[6961x7901] band7 Grid (16-bit integer)
SUBDATASET_7_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:atmos_opacity
SUBDATASET_7_DESC=[6961x7901] atmos_opacity Grid (16-bit integer)
SUBDATASET_8_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:lndsr_QA
SUBDATASET_8_DESC=[6961x7901] lndsr_QA Grid (16-bit integer)
SUBDATASET_9_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band6
SUBDATASET_9_DESC=[6961x7901] band6 Grid (16-bit integer)
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 512.0)
Upper Right ( 512.0, 0.0)
Lower Right ( 512.0, 512.0)
Center ( 256.0, 256.0)
HDFLooK:
Global attributes: 26
DataProvider: UMDLANDSAT_5TM2010-12-16T00:00:00.000000Z2012-02-22T00:00:00.000000Z SolarZenith: 42.0201
SolarAzimuth: 141.424
2 WRS_Path: 169
WRS_Row: 54
NumberOfBands: 6
BandNumbers: 1, 2, 3, 4, 5, 7
L5TSRL5TSR.a2010350.w2p169r054.020.2012117105207.hdf2012-04-26T10:52:07Z1.0.91.0.4 WestBoundingCoordinate: 36.62
EastBoundingCoordinate: 38.7807
NorthBoundingCoordinate: 9.61827
SouthBoundingCoordinate: 7.72286
OrientationAngle: 0
PixelSize: 30
HDFEOS_V2.4-----------------------------------------------------------------------------------
GROUP=SwathStructure
END_GROUP=SwathStructure
GROUP=GridStructure
GROUP=GRID_1
GridName="Grid"
XDim=7901
YDim=6961
UpperLeftPointMtrs=(238785.000000,1063215.000000)
LowerRightMtrs=(475815.000000,854385.000000)
Projection=GCTP_UTM
ZoneCode=37
SphereCode=12
GridOrigin=HDFE_GD_UL
GROUP=Dimension
END_GROUP=Dimension
GROUP=DataField
OBJECT=DataField_0
DataFieldName="band1"
DataType=DFNT_INT16
DimList=("YDim","XDim")
END_OBJECT=DataField_0
OBJECT=DataField_1
DataFieldName="band2"
DataType=DFNT_INT16
END_OBJECT=DataField_1
OBJECT=DataField_2
DataFieldName="band3"
DataType=DFNT_INT16
END_OBJECT=DataField_2
OBJECT=DataField_3
DataFieldName="band4"
DataType=DFNT_INT16
END_OBJECT=DataField_3
OBJECT=DataField_4
DataFieldName="band5"
DataType=DFNT_INT16
END_OBJECT=DataField_4
OBJECT=DataField_5
DataFieldName="band7"
DataType=DFNT_INT16
END_OBJECT=DataField_5
OBJECT=DataField_6
DataFieldName="atmos_opacity"
DataType=DFNT_INT16
END_OBJECT=DataField_6
OBJECT=DataField_7
DataFieldName="lndsr_QA"
DataType=DFNT_INT16
END_OBJECT=DataField_7
OBJECT=DataField_9
DataFieldName="band6"
DataType=DFNT_INT16
END_OBJECT=DataField_9
END_GROUP=DataField
GROUP=MergedFields
END_GROUP=MergedFields
END_GROUP=GRID_1
END_GROUP=GridStructure
GROUP=PointStructure
END_GROUP=PointStructure
END
