[Qgis-user] Re: Add delimited text layer doesn't import all records from CSV file
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Wed May 2 22:49:02 PDT 2012
William Hudspeth <bhudspeth at ...> writes:
> Hello,
> I am trying to import a CSV file with X and Y coordinates specified in
> two columns. Not all of the records are imported. Any ideas?
> Bill
I would check first if some rows miss fields or have extra fields. The latter
may happen if separating character is used in field values. You can also have a
try with GDAL csv driver http://gdal.org/ogr/drv_csv.html
-Jukka Rahkonen-
