[Qgis-developer] Re: [Qgis-user] Raster Layers obscuring other layers using master
Tim Sutton lists at linfiniti.com
Thu May 3 06:59:25 PDT 2012
Hi
On Thu, May 3, 2012 at 2:41 PM, Giovanni Manghi
<giovanni.manghi at faunalia.pt> wrote:
> On Thu, 2012-05-03 at 08:38 -0400, John Callahan wrote:
>> I have exactly the same problem.  The rasters I used were both TIF and
>> sid images.  They covered the rasters, regardless of its layer
>> positioning.  Works fine with the latest stable build (1.7.x).
Can you check that you are indeed using the legend to manage render order?
Regards
Tim
> Someone can test if this issue affects also the code freezed for 1.8? If
> yes please file a ticket and -as it is a regression- tag it as
> "blocker".
> cheers
> -- Giovanni --
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
