[Qgis-user] Raster Layers obscuring other layers using master
Giovanni Manghi
giovanni.manghi at faunalia.pt
Thu May 3 05:41:06 PDT 2012
On Thu, 2012-05-03 at 08:38 -0400, John Callahan wrote:
> I have exactly the same problem. The rasters I used were both TIF and
> sid images. They covered the rasters, regardless of its layer
> positioning. Works fine with the latest stable build (1.7.x).
Someone can test if this issue affects also the code freezed for 1.8? If
yes please file a ticket and -as it is a regression- tag it as
"blocker".
cheers
-- Giovanni --
