[Qgis-developer] Re: [Qgis-user] Raster Layers obscuring other layers using master
Tim Sutton
lists at linfiniti.com
Thu May 3 12:35:01 PDT 2012
Hi
On Thu, May 3, 2012 at 4:03 PM, James Stott
<James.Stott at npaconsult.co.uk> wrote:
> That was the problem.
> I never set QGIS to change from rendering using the legend.
> Is there a reason this might have changed on its own?
It has happened to me once or twice but I assumed it was wild clicking
on the wrong thing by myself rather than a particular bug. If you
think it is a bug, try to find a way to reproduce it so we can try to
fix it.
Regards
Tim
> James Stott BSc (Hons) MSc | Senior Professional
> Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
> T: 01225 445548 | M: -
> http://www.npaconsult.co.uk/
> -----Original Message-----
> From: Tim Sutton [mailto:lists at linfiniti.com]
> Sent: 03 May 2012 14:59
> To: giovanni.manghi at faunalia.pt
> Cc: John Callahan; qgis-user at lists.osgeo.org; Qgis-developer at lists.osgeo.org; James Stott
> Subject: Re: [Qgis-developer] Re: [Qgis-user] Raster Layers obscuring other layers using master
> Hi
> On Thu, May 3, 2012 at 2:41 PM, Giovanni Manghi <giovanni.manghi at faunalia.pt> wrote:
>> On Thu, 2012-05-03 at 08:38 -0400, John Callahan wrote:
>>> I have exactly the same problem. The rasters I used were both TIF
>>> and sid images. They covered the rasters, regardless of its layer
>>> positioning. Works fine with the latest stable build (1.7.x).
> Can you check that you are indeed using the legend to manage render order?
> Regards
> Tim
>> Someone can test if this issue affects also the code freezed for 1.8?
>> If yes please file a ticket and -as it is a regression- tag it as
>> "blocker".
>> cheers
>> -- Giovanni --
>> Qgis-developer mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager) ==============================================
> Please do not email me off-list with technical support questions. Using the lists will gain more exposure for your issues and the knowledge surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> http://www.npaconsult.co.uk/http://www.npaconsult.co.uk/about-news.asp
> http://www.npaconsult.co.uk/terms.asp
> This Electronic Transmission is intended only for the attention of the addressee. It may contain privileged and confidential information. If you are not the person for whom it is intended, you must not copy, distribute or take any action in reliance on it. If you have received this electronic transmission in error please notify us immediately by telephone, delete the transmission and destroy any hard copies.
> Nicholas Pearson Associates has used all reasonable efforts to ensure that this message and any attachments are free from viruses.
> Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44 (0) 01225 445548, Fax: +44 (0) 01225 312387, Website: http://www.npaconsult.co.uk/
Skype: timlinux
