[Qgis-developer] Re: [Qgis-user] Raster Layers obscuring other layers using master
John Callahan
john.callahan at udel.edu
Fri May 4 06:21:54 PDT 2012
At the bottom of the Layers window, there is a "Control rendering order"
checkbox. If that box is checked, then it behaves as expected. If not,
well, it doesn't (you'll need to look at the Layer Order window.) Perhaps
the issue is that the checkbox is not checked (turned off) by default.
Probably it should be checked by default.
- John
On Thu, May 3, 2012 at 3:35 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> On Thu, May 3, 2012 at 4:03 PM, James Stott
> <James.Stott at npaconsult.co.uk> wrote:
> > That was the problem.
> > I never set QGIS to change from rendering using the legend.
> > Is there a reason this might have changed on its own?
> It has happened to me once or twice but I assumed it was wild clicking
> on the wrong thing by myself rather than a particular bug. If you
> think it is a bug, try to find a way to reproduce it so we can try to
> fix it.
> Regards
> Tim
> > James Stott BSc (Hons) MSc | Senior Professional
> > Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
> > T: 01225 445548 | M: -
> > http://www.npaconsult.co.uk/
> > -----Original Message-----
> > From: Tim Sutton [mailto:lists at linfiniti.com]
> > Sent: 03 May 2012 14:59
> > To: giovanni.manghi at faunalia.pt
> > Cc: John Callahan; qgis-user at lists.osgeo.org;
> Qgis-developer at lists.osgeo.org; James Stott
> > Subject: Re: [Qgis-developer] Re: [Qgis-user] Raster Layers obscuring
> > Hi
> > On Thu, May 3, 2012 at 2:41 PM, Giovanni Manghi <
> giovanni.manghi at faunalia.pt> wrote:
> >> On Thu, 2012-05-03 at 08:38 -0400, John Callahan wrote:
> >>> I have exactly the same problem. The rasters I used were both TIF
> >>> and sid images. They covered the rasters, regardless of its layer
> >>> positioning. Works fine with the latest stable build (1.7.x).
> > Can you check that you are indeed using the legend to manage render
> order?
> > Regards
> > Tim
> >> Someone can test if this issue affects also the code freezed for 1.8?
> >> If yes please file a ticket and -as it is a regression- tag it as
> >> "blocker".
> >> cheers
> >> -- Giovanni --
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> > Please do not email me off-list with technical support questions. Using
> the lists will gain more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> > Visit http://linfiniti.com to find out about:
> > * QGIS programming and support services
> > * Mapserver and PostGIS based hosting plans
> > * FOSS Consulting Services
> > Skype: timlinux
> > Irc: timlinux on #qgis at freenode.net
> > http://www.npaconsult.co.uk/http://www.npaconsult.co.uk/about-news.asp
> > http://www.npaconsult.co.uk/terms.asp
> > This Electronic Transmission is intended only for the attention of the
> addressee. It may contain privileged and confidential information. If you
> are not the person for whom it is intended, you must not copy, distribute
> or take any action in reliance on it. If you have received this electronic
> transmission in error please notify us immediately by telephone, delete the
> transmission and destroy any hard copies.
> > Nicholas Pearson Associates has used all reasonable efforts to ensure
> that this message and any attachments are free from viruses.
> > Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44
> (0) 01225 445548, Fax: +44 (0) 01225 312387, Website:
> support questions. Using the lists will gain
> Skype: timlinux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120504/b378c515/attachment.html>
