[Qgis-user] Re: QGIS Server Ubuntu 11.04 GetCapabilities not showing layers
Bernhard Ströbl bernhard.stroebl at jena.de
Fri May 4 02:11:45 PDT 2012
Wait a minute... if you are you trying to access the WMS layer from QGIS
desktop you need to tick "Ignore GetMap URI reported in capabilities'
Bernhard
Am 04.05.2012 10:56, schrieb anacm:
> Thanks for your interest and time, Marco and Giovanni.
> The GetCapabilities seems to show the same CRS than the project. I have read
> that there is an issue between QGIS order of the coordinates of the Bounding
> Box and the WMS standard (it is reported in
> http://forum.qgis.org/viewtopic.php?f=2&t=9809&p=23292&hilit=mapserver&sid=1bcb41ded32a32ad35d26af574f10cb4#p23292).
> I have checked these, trying different orders of maxx, maxy, minx, miny
> coordinates and still doesn't work.
> I have changed the permissions of all the files in /usr/lib/cgi-bin to allow
> everything to everybody (I guess it should not be necessary, but I do not
> know what else to do). The directory where the qgis_mapserv.fcgi is has also
> the .qgs file, the jpeg file from where I built the layer in qgis, and some
> other files: admin.slf,  qgismapserv.fcgi, wms_metadata.xml . This is the
> request I use:
> http://localhost/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=-749.167,-22.275,119.167,913.275&CRS=EPSG:4326&WIDTH=1077&HEIGHT=552&FORMAT=image/jpeg&DPI=96
> Since it seems that apache2 is working and there is no error, I do not know
> exactly what else try. My fcgdi.conf file is this (I used apt-get to install
> QGIS)
> <IfModule mod_fcgid.c>
>    AddHandler	fcgid-script .fcgi
>    FcgidConnectTimeout 20
> </IfModule>
> The .qgs file is stored with absolute paths, it has a single raster layer.
> In WMS Server options, I fill the dat and choose the extension from the
> actual map. The SCR restrictions are EPSG:4326, and I tick the WKT geometry
> options. The GetCapabilites response is this:
> http://osgeo-org.1560.n6.nabble.com/file/n4951739/GetCapabilities.xml
> GetCapabilities.xml
> I'll check the qgis-dev possibility anyway, thanks for the idea. But if
> anyone could give a hint about what it's failing here, it would be really
> helpful.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/QGIS-Server-Ubuntu-11-04-GetCapabilities-not-showing-layers-tp4945055p4951739.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> ________ Information from NOD32 ________
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
