[Qgis-user] R example scripts in QGIS Sextante Toolbox: complains about SAGA
Victor Olaya
volayaf at gmail.com
Mon May 7 02:18:12 PDT 2012
Agustin
That is a typo that is already corrected in the SVN version. It really
means that R is not installed (or at least, SEXTANTE cannot find it).
You should make sure that R is available (opening a console and typing
"r" should work, with no need of additional settings)
i assume that you are using linux, right?
Regards
Victor
2012/5/7 Agustin Lobo <alobolistas at gmail.com>:
> Whenever I try to use one of the R scripts included as example scripts
> in the SEXTANTE
> version of QGIS, I get:
> It seems that SAGA is not correctly installed in your system.
> Please install it before running SAGA algorithms.
> Do I really need SAGA for these scripts or is this an error of the checking?
> In any case, I do have SAGA 2.0.7
> Using SEXTANTE v1.0.4 for QGIS 1.7.4 on Ubuntu 10.04
> Thanks,
> Agus
> Qgis-user mailing list
