[Qgis-user] R example scripts in QGIS Sextante Toolbox: complains about SAGA
Agustin Lobo
alobolistas at gmail.com
Mon May 7 02:31:15 PDT 2012
Victor,
yes, I'm using ubuntu 10.04 as mentioned. And R works.
What do regular users have to do in order to get the SVN version? compiling?
If this is a python plugin (SEXTANTE Geoprocessing platform for QGIS),
should not the bug fixes be immediately available to users by
installing the new version of the plugin?
Thanks
Agus
2012/5/7 Victor Olaya <volayaf at gmail.com>:
> Agustin
> That is a typo that is already corrected in the SVN version. It really
> means that R is not installed (or at least, SEXTANTE cannot find it).
> You should make sure that R is available (opening a console and typing
> "r" should work, with no need of additional settings)
> i assume that you are using linux, right?
> Regards
> Victor
> 2012/5/7 Agustin Lobo <alobolistas at gmail.com>:
>> Whenever I try to use one of the R scripts included as example scripts
>> in the SEXTANTE
>> version of QGIS, I get:
>> It seems that SAGA is not correctly installed in your system.
>> Please install it before running SAGA algorithms.
>> Do I really need SAGA for these scripts or is this an error of the checking?
>> In any case, I do have SAGA 2.0.7
>> Using SEXTANTE v1.0.4 for QGIS 1.7.4 on Ubuntu 10.04
>> Thanks,
>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
