[Qgis-user] PostGIS Manager compatibility issue with PostGIS 2.0
    Salvatore Larosa
    lrssvtml at gmail.com
    Mon May  7 05:56:59 PDT 2012
Il giorno lun, 07/05/2012 alle 10.58 +0200, G. Allegri ha scritto:
> When attempting to use the PM with a PostGIS 2.0 db I obtain the same
> error as in  http://hub.qgis.org/issues/5201, caused by the deprecated
> postgis_user_stats() call.
> The plugin manager doesn't suggest updates to the PM.
> I haven't found the tracker for the plugin. Where is it located?
Hi Giovanni,
I can not even find it!
However, taking advantage of your mail, I noticed a similarity
(duplicates) between plugins PostGIS Manager, Spatialite Manager and
RT_SQL Layer. IMO they should be removed. DBManager already does all of
that!
Am I wrong?
All the Best,
-SL
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt
