[Qgis-user] PostGIS Manager compatibility issue with PostGIS 2.0
G. Allegri
giohappy at gmail.com
Mon May 7 06:25:02 PDT 2012
DB Manager works fine.
The plugins overlap, but they are contributed plugins, so it's up to the
user choosing wether to use DB Manager or the others.
My note was directed to the PG Manager mantainer...
giovanni
2012/5/7 Salvatore Larosa <lrssvtml at gmail.com>
> Il giorno lun, 07/05/2012 alle 10.58 +0200, G. Allegri ha scritto:
> > When attempting to use the PM with a PostGIS 2.0 db I obtain the same
> > error as in http://hub.qgis.org/issues/5201, caused by the deprecated
> > postgis_user_stats() call.
> > The plugin manager doesn't suggest updates to the PM.
> > I haven't found the tracker for the plugin. Where is it located?
> Hi Giovanni,
> I can not even find it!
> However, taking advantage of your mail, I noticed a similarity
> (duplicates) between plugins PostGIS Manager, Spatialite Manager and
> RT_SQL Layer. IMO they should be removed. DBManager already does all of
> that!
> Am I wrong?
> All the Best,
> -SL
> Salvatore Larosa
> linkedIn: http://linkedin.com/in/larosasalvatore
> twitter: @lrssvt
> skype: s.larosa
> IRC: lrssvt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120507/3ba73e53/attachment.html>
