[Qgis-user] Sextante plugin works except with GRASS
Luca Casagrande
luca.casagrande at gmail.com
Mon May 7 14:50:21 PDT 2012
Hello folks,
I have some troubles running GRASS command using Sextante plugin on Ubuntu
12.04; basically it complains that it can't find the output file.
This is the text from the log:
ALGORITHM|lun mag 07 2012
23:40:58|Sextante.runalg("grass:v.voronoi","/home/luca/prova_editing.shp",True,True,None)
INFO|lun mag 07 2012 23:40:58|GRASS execution commands|g.region
n=4785940.92509 s=4751550.93215 e=809189.765459 w=766364.491229
res=1|v.voronoi input=1336426858.083 -l -t output=output
--overwrite|v.out.ogr -e input=output dsn="/home/luca/sextante/tempdata"
format=ESRI_Shapefile olayer=1336426858.041.shp type=auto
INFO|lun mag 07 2012 23:40:58|GRASS execution console output|Cleaning up
temporary files ...|Starting GRASS ...|Executing
'/home/luca/sextante/grass_batch_job.sh' ...|Welcome to GRASS 6.4.2 (2012)
|ERROR: Vector map <1336426858.083> not found|ERROR: Vector map <output> not
found|Closing monitors ...|Cleaning up temporary files ...|Batch job
'/home/luca/sextante/grass_batch_job.sh' (defined in GRASS_BATCH_JOB
variable) was executed.|Goodbye from GRASS GIS
Saga, mmqgis and gdal are ok!
Thanks!
L.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Sextante-plugin-works-except-with-GRASS-tp4958903.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
