[Qgis-user] Re: Sextante plugin works except with GRASS
Victor Olaya
volayaf at gmail.com
Tue May 8 03:01:32 PDT 2012
Pietro
I think you are using an older version
Please try the latest version (1.0.5) that I have just published. It
should work fine.
Thanks for your interest
Victor
2012/5/8 Pietro Rossin <pierigis at gmail.com>:
> Hello
> same thing seems to happen to me, in windows xp..
> No output is generated by any algorithm except the example one (export
> selected features..)
> Can you please have a look at this?
> http://osgeo-org.1560.n6.nabble.com/SEXTANTE-plugin-problem-doesn-t-create-output-td4957583.html
> Where is the problem? I think I set correctly all the path to output
> folders/apps folders.
> Thanks
> Pietro
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Sextante-plugin-works-except-with-GRASS-tp4958903p4959791.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
