[Qgis-user] Re: Sextante plugin works except with GRASS
Luca Casagrande luca.casagrande at gmail.com
Tue May 8 03:27:21 PDT 2012
Thanks for the help!
I can confirm that GRASS is working fine with Sextante 1.0.5. :)
I noticed that there is no entry in the Plugin menu:
http://ubuntuone.com/4bVCGshtAxeD9Tb36fU27D
Ciao
L.
Victor Olaya-3 wrote
> Pietro
> I think you are using an older version
> Please try the latest version (1.0.5) that I have just published. It
> should work fine.
> Thanks for your interest
> Victor
> 2012/5/8 Pietro Rossin <pierigis@>:
>> Hello
>> same thing seems to happen to me, in windows xp..
>> No output is generated by any algorithm except the example one (export
>> selected features..)
>> Can you please have a look at this?
>> http://osgeo-org.1560.n6.nabble.com/SEXTANTE-plugin-problem-doesn-t-create-output-td4957583.html
>> Where is the problem? I think I set correctly all the path to output
>> folders/apps folders.
>> Thanks
>> Pietro
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/Sextante-plugin-works-except-with-GRASS-tp4958903p4959791.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> Qgis-user at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Qgis-user at .osgeo
View this message in context: http://osgeo-org.1560.n6.nabble.com/Sextante-plugin-works-except-with-GRASS-tp4958903p4960064.html
