[Qgis-user] Re: Sextante plugin works except with GRASS
Luca Casagrande
luca.casagrande at gmail.com
Tue May 8 03:29:03 PDT 2012
All is fine, there's an entry "Analysis" :)
Sorry, I need some sleep..
Luca Casagrande wrote
> Thanks for the help!
> I can confirm that GRASS is working fine with Sextante 1.0.5. :)
> I noticed that there is no entry in the Plugin menu:
> http://ubuntuone.com/4bVCGshtAxeD9Tb36fU27D
> Ciao
> L.
> Victor Olaya-3 wrote
>> Pietro
>> I think you are using an older version
>> Please try the latest version (1.0.5) that I have just published. It
>> should work fine.
>> Thanks for your interest
>> Victor
>> 2012/5/8 Pietro Rossin <pierigis@>:
>>> Hello
>>> same thing seems to happen to me, in windows xp..
>>> No output is generated by any algorithm except the example one (export
>>> selected features..)
>>> Can you please have a look at this?
>>> http://osgeo-org.1560.n6.nabble.com/SEXTANTE-plugin-problem-doesn-t-create-output-td4957583.html
>>> Where is the problem? I think I set correctly all the path to output
>>> folders/apps folders.
>>> Thanks
>>> Pietro
>>> View this message in context:
>>> http://osgeo-org.1560.n6.nabble.com/Sextante-plugin-works-except-with-GRASS-tp4958903p4959791.html
>>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>>> Qgis-user mailing list
>>> Qgis-user at .osgeo
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Qgis-user at .osgeo
View this message in context: http://osgeo-org.1560.n6.nabble.com/Sextante-plugin-works-except-with-GRASS-tp4958903p4960065.html
