[Qgis-user] Re: Sextante plugin works except with GRASS
Pietro Rossin
pierigis at gmail.com
Tue May 8 04:50:30 PDT 2012
Super-duper!
All works fine now!
Thanks a lot Victor
Pietro
2012/5/8 Luca Casagrande [via OSGeo.org] <
ml-node+s1560n4960065h60 at n6.nabble.com>
> All is fine, there's an entry "Analysis" :)
> Sorry, I need some sleep..
> Luca Casagrande wrote
> Thanks for the help!
> I can confirm that GRASS is working fine with Sextante 1.0.5. :)
> I noticed that there is no entry in the Plugin menu:
> http://ubuntuone.com/4bVCGshtAxeD9Tb36fU27D
> Ciao
> L.
> Victor Olaya-3 wrote
> Pietro
> I think you are using an older version
> Please try the latest version (1.0.5) that I have just published. It
> should work fine.
> Thanks for your interest
> Victor
> 2012/5/8 Pietro Rossin <[hidden email]<http://user/SendEmail.jtp?type=node&node=4960065&i=0>>:
> > Hello
> > same thing seems to happen to me, in windows xp..
> > No output is generated by any algorithm except the example one (export
> > selected features..)
> > Can you please have a look at this?
> http://osgeo-org.1560.n6.nabble.com/SEXTANTE-plugin-problem-doesn-t-create-output-td4957583.html
> > Where is the problem? I think I set correctly all the path to output
> > folders/apps folders.
> > Thanks
> > Pietro
> > View this message in context:
> http://osgeo-org.1560.n6.nabble.com/Sextante-plugin-works-except-with-GRASS-tp4958903p4959791.html
> > Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> > Qgis-user mailing list
> > [hidden email] <http://user/SendEmail.jtp?type=node&node=4960065&i=1>
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> [hidden email] <http://user/SendEmail.jtp?type=node&node=4960065&i=2>
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/Sextante-plugin-works-except-with-GRASS-tp4958903p4960065.html
> To unsubscribe from Sextante plugin works except with GRASS, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4958903&code=cGllcmlnaXNAZ21haWwuY29tfDQ5NTg5MDN8MjMwODY1MTQ5>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/Sextante-plugin-works-except-with-GRASS-tp4958903p4960207.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120508/b33011ef/attachment.html>
