[Qgis-user] Re: Sextante plugin works except with GRASS
Victor Olaya
volayaf at gmail.com
Tue May 8 11:36:47 PDT 2012
That is a bug, clearly.
Since there is no input cellsize (all inputs are vectors), it is using
the defautl one instead of the one you entered in the settigns. I have
just changed that behaviour in the SVN version
Thanks!
2012/5/8 Pietro Rossin <pierigis at gmail.com>:
> Hello again
> I'm facing now a different problem with grass module.
> I am trying to make some test on interpolation of point vector data.
> The module I try to use is v.surf.idw.
> Under sextante option and configuration>general I set an output folder and
> under Grass commands I set the region cellsize = 100 and flagged "use min
> covering region".
> If I try to run the v.surf.idw command with 42 point and -n set to YES the
> computer start working but never ends with CPU working 100% (one cpu, so
> 50%).
> If I try the same operation with the -n set to NO, the module comes to the
> end sayng that it cannot load the output.
> It seems that there is a memory problem, because the cell resolution is
> automatically set to 1m...
> Here are the logs
> GRASS execution commands
> g.region n=5098753.0 s=5077746.0 e=2367660.0 w=2339468.0 res=1
> v.in.ogr min_area=-1 dsn="E:\GIS\temp" layer=tempiterpolation
> output=tmp1336482424014 --overwrite -o
> v.surf.idw input=tmp1336482424014 npoints=8 power=2 column=dtm10m
> output=output --overwrite
> g.region rast=output
> r.out.gdal -c createopt="TFW=YES,COMPRESS=LZW" input=output
> output="C:/Documents and Settings/rossinp/Desktop/pipp.tif"
> GRASS execution console output
> C:\>set HOME=C:\Documents and Settings\rossinp
> C:\>set GISRC=C:\Documents and Settings\rossinp\sextante\sextante.gisrc
> C:\>set GRASS_SH=C:\OSgeo4w\apps\msys\bin\sh.exe
> C:\>set
> PATH=C:\OSgeo4w\apps\msys\bin;C:\OSgeo4w\apps\msys\lib;C:/OSgeo4w/apps/grass/GRASS-~1.2/bin;C:/OSgeo4w/apps/grass/GRASS-~1.2/scripts;C:/OSgeo4w/apps/qgis-dev/./grass/scripts/;C:/OSgeo4w/apps/qgis-dev/bin;C:\OSgeo4w\apps\grass\grass-6.4.2\bin;C:\OSgeo4w\apps\grass\grass-6.4.2\lib;C:\OSgeo4w\apps\msys\bin;C:\OSgeo4w\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Programmi\File
> comuni\Autodesk
> Shared\;C:\OSgeo4w\apps\msys\bin;C:\OSgeo4w\apps\Python27\Scripts;C:\OSgeo4w\apps\qgis-dev\bin;C:\OSgeo4w\apps\grass\grass-6.4.2\lib
> C:\>set WINGISBASE=C:\OSgeo4w\apps\grass\grass-6.4.2\
> C:\>set GISBASE=C:\OSgeo4w\apps\grass\grass-6.4.2\
> C:\>set GRASS_PROJSHARE=C:\OSgeo4w\apps\grass\grass-6.4.2\\share\proj
> C:\>set GRASS_MESSAGE_FORMAT=gui
> C:\>if "" == "" set
> PATH=C:\OSgeo4w\apps\grass\grass-6.4.2\\bin;C:\OSgeo4w\apps\grass\grass-6.4.2\\lib;C:\OSgeo4w\apps\msys\bin;C:\OSgeo4w\apps\msys\lib;C:/OSgeo4w/apps/grass/GRASS-~1.2/bin;C:/OSgeo4w/apps/grass/GRASS-~1.2/scripts;C:/OSgeo4w/apps/qgis-dev/./grass/scripts/;C:/OSgeo4w/apps/qgis-dev/bin;C:\OSgeo4w\apps\grass\grass-6.4.2\bin;C:\OSgeo4w\apps\grass\grass-6.4.2\lib;C:\OSgeo4w\apps\msys\bin;C:\OSgeo4w\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Programmi\File
> comuni\Autodesk
> C:\>if not "" == "" set
> PATH=C:\OSgeo4w\apps\grass\grass-6.4.2\\bin;C:\OSgeo4w\apps\grass\grass-6.4.2\\lib;;C:\OSgeo4w\apps\grass\grass-6.4.2\\bin;C:\OSgeo4w\apps\grass\grass-6.4.2\\lib;C:\OSgeo4w\apps\msys\bin;C:\OSgeo4w\apps\msys\lib;C:/OSgeo4w/apps/grass/GRASS-~1.2/bin;C:/OSgeo4w/apps/grass/GRASS-~1.2/scripts;C:/OSgeo4w/apps/qgis-dev/./grass/scripts/;C:/OSgeo4w/apps/qgis-dev/bin;C:\OSgeo4w\apps\grass\grass-6.4.2\bin;C:\OSgeo4w\apps\grass\grass-6.4.2\lib;C:\OSgeo4w\apps\msys\bin;C:\OSgeo4w\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Programmi\File
> comuni\Autodesk
> C:\>set GRASS_VERSION=6.4.0
> C:\>if not "" == "" goto langset
> C:\>FOR /F "usebackq delims==" %i IN
> (`"C:\OSgeo4w\apps\grass\grass-6.4.2\\etc\winlocale"`) DO @set LANG=%i
> C:\>set PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PY
> C:\>set
> PYTHONPATH=C:/OSgeo4w/apps/grass/GRASS-~1.2/etc/python;C:\OSgeo4w\apps\orfeotoolbox\wrapping\lib;C:\OSgeo4w\apps\orfeotoolbox\wrapping\Python;C:\OSgeo4w\apps\orfeotoolbox\python;C:\Programmi\ArcGIS\bin;C:\OSgeo4w\apps\grass\grass-6.4.2\\etc\python;C:\OSgeo4w\apps\grass\grass-6.4.2\\etc\wxpython\n
> C:\>g.gisenv.exe set="MAPSET=user"
> C:\>g.gisenv.exe set="LOCATION=temp_location"
> C:\>g.gisenv.exe set="LOCATION_NAME=temp_location"
> C:\>g.gisenv.exe set="GISDBASE=C:\Documents and
> Settings\rossinp\sextante\tempdata\grassdata"
> C:\>g.gisenv.exe set="GRASS_GUI=text"
> C:\>g.region n=5098753.0 s=5077746.0 e=2367660.0 w=2339468.0 res=1
> C:\>v.in.ogr min_area=-1 dsn="E:\GIS\temp" layer=tempiterpolation
> GRASS_INFO_MESSAGE(3580,1): Over-riding projection check
> GRASS_INFO_END(3580,1)
> GRASS_INFO_MESSAGE(3580,2): Layer: tempiterpolation
> GRASS_INFO_END(3580,2)
> GRASS_INFO_MESSAGE(3580,3): Conteggio dei poligoni per 42 elementi in
> corso...
> GRASS_INFO_END(3580,3)
> GRASS_INFO_MESSAGE(3580,4): Importing map 42 features...
> GRASS_INFO_END(3580,4)
> GRASS_INFO_MESSAGE(3580,5):
> GRASS_INFO_END(3580,5)
> GRASS_INFO_MESSAGE(3580,6): Si sta ricreando la topologia per il vettore
> <tmp1336482424014_tmp>...
> GRASS_INFO_END(3580,6)
> GRASS_INFO_MESSAGE(3580,7): Registrando primitive...
> GRASS_INFO_END(3580,7)
> GRASS_INFO_MESSAGE(3580,8): 42 primitive registrate
> GRASS_INFO_END(3580,8)
> GRASS_INFO_MESSAGE(3580,9): 42 vertici registrati
> GRASS_INFO_END(3580,9)
> GRASS_INFO_MESSAGE(3580,10): Numero di nodi: 42
> GRASS_INFO_END(3580,10)
> GRASS_INFO_MESSAGE(3580,11): Numero di primitive:42
> GRASS_INFO_END(3580,11)
> GRASS_INFO_MESSAGE(3580,12): Numero di punti:42
> GRASS_INFO_END(3580,12)
> GRASS_INFO_MESSAGE(3580,13): Numero di linee:0
> GRASS_INFO_END(3580,13)
> GRASS_INFO_MESSAGE(3580,14): Numero di confini:0
> GRASS_INFO_END(3580,14)
> GRASS_INFO_MESSAGE(3580,15): Numero di centroidi:0
> GRASS_INFO_END(3580,15)
> GRASS_INFO_MESSAGE(3580,16): Numero di aree: -
> GRASS_INFO_END(3580,16)
> GRASS_INFO_MESSAGE(3580,17): Numero di isole:-
> GRASS_INFO_END(3580,17)
> GRASS_INFO_MESSAGE(3580,18): Si sta ricreando la topologia per il vettore
> <tmp1336482424014>...
> GRASS_INFO_END(3580,18)
> GRASS_INFO_MESSAGE(3580,19): Registrando primitive...
> GRASS_INFO_END(3580,19)
> GRASS_INFO_MESSAGE(3580,20): 42 primitive registrate
> GRASS_INFO_END(3580,20)
> GRASS_INFO_MESSAGE(3580,21): 42 vertici registrati
> GRASS_INFO_END(3580,21)
> GRASS_INFO_MESSAGE(3580,22): Costruendo aree...
> GRASS_INFO_END(3580,22)
> GRASS_INFO_MESSAGE(3580,23): 0 aree create
> GRASS_INFO_END(3580,23)
> GRASS_INFO_MESSAGE(3580,24): 0 isole create
> GRASS_INFO_END(3580,24)
> GRASS_INFO_MESSAGE(3580,25): Isole allegate...
> GRASS_INFO_END(3580,25)
> GRASS_INFO_MESSAGE(3580,26): Centroidi allegati...
> GRASS_INFO_END(3580,26)
> GRASS_INFO_MESSAGE(3580,27): Numero di nodi: 42
> GRASS_INFO_END(3580,27)
> GRASS_INFO_MESSAGE(3580,28): Numero di primitive:42
> GRASS_INFO_END(3580,28)
> GRASS_INFO_MESSAGE(3580,29): Numero di punti:42
> GRASS_INFO_END(3580,29)
> GRASS_INFO_MESSAGE(3580,30): Numero di linee:0
> GRASS_INFO_END(3580,30)
> GRASS_INFO_MESSAGE(3580,31): Numero di confini:0
> GRASS_INFO_END(3580,31)
> GRASS_INFO_MESSAGE(3580,32): Numero di centroidi:0
> GRASS_INFO_END(3580,32)
> GRASS_INFO_MESSAGE(3580,33): Numero di aree:0
> GRASS_INFO_END(3580,33)
> GRASS_INFO_MESSAGE(3580,34): Numero di isole:0
> GRASS_INFO_END(3580,34)
> C:\>v.surf.idw input=tmp1336482424014 npoints=8 power=2 column=dtm10m
> GRASS_INFO_ERROR(2036,1): G_malloc: impossibile allocare 112768 bytes a
> main.c:169
> GRASS_INFO_END(2036,1)
> C:\>g.region rast=output
> GRASS_INFO_ERROR(2012,1): Mappa raster <output> non trovata
> GRASS_INFO_END(2012,1)
> C:\>r.out.gdal -c createopt="TFW=YES,COMPRESS=LZW" input=output
> GRASS_INFO_ERROR(1348,1): Mappa raster o gruppo <output> non trovato
> GRASS_INFO_END(1348,1)
> C:\>exit
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Sextante-plugin-works-except-with-GRASS-tp4958903p4960419.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
