[Qgis-user] Re: Sextante plugin works except with GRASS
Pietro Rossin
pierigis at gmail.com
Wed May 9 00:57:44 PDT 2012
Ok
Is there any way to install the svn version?
So I can test if there is any other problem?
Thanks for your work Victor,
This plugin will be super useful one!
Pietro
2012/5/8 Victor Olaya-3 [via OSGeo.org] <
ml-node+s1560n4961106h31 at n6.nabble.com>
> That is a bug, clearly.
> Since there is no input cellsize (all inputs are vectors), it is using
> the defautl one instead of the one you entered in the settigns. I have
> just changed that behaviour in the SVN version
> Thanks!
> 2012/5/8 Pietro Rossin <[hidden email]<http://user/SendEmail.jtp?type=node&node=4961106&i=0>>:
> > Hello again
> > I'm facing now a different problem with grass module.
> > I am trying to make some test on interpolation of point vector data.
> > The module I try to use is v.surf.idw.
> > Under sextante option and configuration>general I set an output folder
> and
> > under Grass commands I set the region cellsize = 100 and flagged "use
> min
> > covering region".
> > If I try to run the v.surf.idw command with 42 point and -n set to YES
> the
> > computer start working but never ends with CPU working 100% (one cpu, so
> > 50%).
> > If I try the same operation with the -n set to NO, the module comes to
> the
> > end sayng that it cannot load the output.
> > It seems that there is a memory problem, because the cell resolution is
> > automatically set to 1m...
> > Here are the logs
> > GRASS execution commands
> > g.region n=5098753.0 s=5077746.0 e=2367660.0 w=2339468.0 res=1
> > v.in.ogr min_area=-1 dsn="E:\GIS\temp" layer=tempiterpolation
> > output=tmp1336482424014 --overwrite -o
> > v.surf.idw input=tmp1336482424014 npoints=8 power=2 column=dtm10m
> > output=output --overwrite
> > g.region rast=output
> > r.out.gdal -c createopt="TFW=YES,COMPRESS=LZW" input=output
> > output="C:/Documents and Settings/rossinp/Desktop/pipp.tif"
> > GRASS execution console output
> > C:\>set HOME=C:\Documents and Settings\rossinp
> > C:\>set GISRC=C:\Documents and Settings\rossinp\sextante\sextante.gisrc
> > C:\>set GRASS_SH=C:\OSgeo4w\apps\msys\bin\sh.exe
> > C:\>set
> PATH=C:\OSgeo4w\apps\msys\bin;C:\OSgeo4w\apps\msys\lib;C:/OSgeo4w/apps/grass/GRASS-~1.2/bin;C:/OSgeo4w/apps/grass/GRASS-~1.2/scripts;C:/OSgeo4w/apps/qgis-dev/./grass/scripts/;C:/OSgeo4w/apps/qgis-dev/bin;C:\OSgeo4w\apps\grass\grass-6.4.2\bin;C:\OSgeo4w\apps\grass\grass-6.4.2\lib;C:\OSgeo4w\apps\msys\bin;C:\OSgeo4w\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Programmi\File
> > comuni\Autodesk
> Shared\;C:\OSgeo4w\apps\msys\bin;C:\OSgeo4w\apps\Python27\Scripts;C:\OSgeo4w\apps\qgis-dev\bin;C:\OSgeo4w\apps\grass\grass-6.4.2\lib
> > C:\>set WINGISBASE=C:\OSgeo4w\apps\grass\grass-6.4.2\
> > C:\>set GISBASE=C:\OSgeo4w\apps\grass\grass-6.4.2\
> > C:\>set GRASS_PROJSHARE=C:\OSgeo4w\apps\grass\grass-6.4.2\\share\proj
> > C:\>set GRASS_MESSAGE_FORMAT=gui
> > C:\>if "" == "" set
> PATH=C:\OSgeo4w\apps\grass\grass-6.4.2\\bin;C:\OSgeo4w\apps\grass\grass-6.4.2\\lib;C:\OSgeo4w\apps\msys\bin;C:\OSgeo4w\apps\msys\lib;C:/OSgeo4w/apps/grass/GRASS-~1.2/bin;C:/OSgeo4w/apps/grass/GRASS-~1.2/scripts;C:/OSgeo4w/apps/qgis-dev/./grass/scripts/;C:/OSgeo4w/apps/qgis-dev/bin;C:\OSgeo4w\apps\grass\grass-6.4.2\bin;C:\OSgeo4w\apps\grass\grass-6.4.2\lib;C:\OSgeo4w\apps\msys\bin;C:\OSgeo4w\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Programmi\File
> > comuni\Autodesk
> > C:\>if not "" == "" set
> PATH=C:\OSgeo4w\apps\grass\grass-6.4.2\\bin;C:\OSgeo4w\apps\grass\grass-6.4.2\\lib;;C:\OSgeo4w\apps\grass\grass-6.4.2\\bin;C:\OSgeo4w\apps\grass\grass-6.4.2\\lib;C:\OSgeo4w\apps\msys\bin;C:\OSgeo4w\apps\msys\lib;C:/OSgeo4w/apps/grass/GRASS-~1.2/bin;C:/OSgeo4w/apps/grass/GRASS-~1.2/scripts;C:/OSgeo4w/apps/qgis-dev/./grass/scripts/;C:/OSgeo4w/apps/qgis-dev/bin;C:\OSgeo4w\apps\grass\grass-6.4.2\bin;C:\OSgeo4w\apps\grass\grass-6.4.2\lib;C:\OSgeo4w\apps\msys\bin;C:\OSgeo4w\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Programmi\File
> > comuni\Autodesk
> > C:\>set GRASS_VERSION=6.4.0
> > C:\>if not "" == "" goto langset
> > C:\>FOR /F "usebackq delims==" %i IN
> > (`"C:\OSgeo4w\apps\grass\grass-6.4.2\\etc\winlocale"`) DO @set LANG=%i
> > C:\>set PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PY
> > C:\>set
> PYTHONPATH=C:/OSgeo4w/apps/grass/GRASS-~1.2/etc/python;C:\OSgeo4w\apps\orfeotoolbox\wrapping\lib;C:\OSgeo4w\apps\orfeotoolbox\wrapping\Python;C:\OSgeo4w\apps\orfeotoolbox\python;C:\Programmi\ArcGIS\bin;C:\OSgeo4w\apps\grass\grass-6.4.2\\etc\python;C:\OSgeo4w\apps\grass\grass-6.4.2\\etc\wxpython\n
> > C:\>g.gisenv.exe set="MAPSET=user"
> > C:\>g.gisenv.exe set="LOCATION=temp_location"
> > C:\>g.gisenv.exe set="LOCATION_NAME=temp_location"
> > C:\>g.gisenv.exe set="GISDBASE=C:\Documents and
> > Settings\rossinp\sextante\tempdata\grassdata"
> > C:\>g.gisenv.exe set="GRASS_GUI=text"
> > C:\>g.region n=5098753.0 s=5077746.0 e=2367660.0 w=2339468.0 res=1
> > C:\>v.in.ogr min_area=-1 dsn="E:\GIS\temp" layer=tempiterpolation
> > GRASS_INFO_MESSAGE(3580,1): Over-riding projection check
> > GRASS_INFO_END(3580,1)
> > GRASS_INFO_MESSAGE(3580,2): Layer: tempiterpolation
> > GRASS_INFO_END(3580,2)
> > GRASS_INFO_MESSAGE(3580,3): Conteggio dei poligoni per 42 elementi in
> > corso...
> > GRASS_INFO_END(3580,3)
> > GRASS_INFO_MESSAGE(3580,4): Importing map 42 features...
> > GRASS_INFO_END(3580,4)
> > GRASS_INFO_MESSAGE(3580,5):
> > GRASS_INFO_END(3580,5)
> > GRASS_INFO_MESSAGE(3580,6): Si sta ricreando la topologia per il vettore
> > <tmp1336482424014_tmp>...
> > GRASS_INFO_END(3580,6)
> > GRASS_INFO_MESSAGE(3580,7): Registrando primitive...
> > GRASS_INFO_END(3580,7)
> > GRASS_INFO_MESSAGE(3580,8): 42 primitive registrate
> > GRASS_INFO_END(3580,8)
> > GRASS_INFO_MESSAGE(3580,9): 42 vertici registrati
> > GRASS_INFO_END(3580,9)
> > GRASS_INFO_MESSAGE(3580,10): Numero di nodi: 42
> > GRASS_INFO_END(3580,10)
> > GRASS_INFO_MESSAGE(3580,11): Numero di primitive:42
> > GRASS_INFO_END(3580,11)
> > GRASS_INFO_MESSAGE(3580,12): Numero di punti:42
> > GRASS_INFO_END(3580,12)
> > GRASS_INFO_MESSAGE(3580,13): Numero di linee:0
> > GRASS_INFO_END(3580,13)
> > GRASS_INFO_MESSAGE(3580,14): Numero di confini:0
> > GRASS_INFO_END(3580,14)
> > GRASS_INFO_MESSAGE(3580,15): Numero di centroidi:0
> > GRASS_INFO_END(3580,15)
> > GRASS_INFO_MESSAGE(3580,16): Numero di aree: -
> > GRASS_INFO_END(3580,16)
> > GRASS_INFO_MESSAGE(3580,17): Numero di isole:-
> > GRASS_INFO_END(3580,17)
> > GRASS_INFO_MESSAGE(3580,18): Si sta ricreando la topologia per il
> vettore
> > <tmp1336482424014>...
> > GRASS_INFO_END(3580,18)
> > GRASS_INFO_MESSAGE(3580,19): Registrando primitive...
> > GRASS_INFO_END(3580,19)
> > GRASS_INFO_MESSAGE(3580,20): 42 primitive registrate
> > GRASS_INFO_END(3580,20)
> > GRASS_INFO_MESSAGE(3580,21): 42 vertici registrati
> > GRASS_INFO_END(3580,21)
> > GRASS_INFO_MESSAGE(3580,22): Costruendo aree...
> > GRASS_INFO_END(3580,22)
> > GRASS_INFO_MESSAGE(3580,23): 0 aree create
> > GRASS_INFO_END(3580,23)
> > GRASS_INFO_MESSAGE(3580,24): 0 isole create
> > GRASS_INFO_END(3580,24)
> > GRASS_INFO_MESSAGE(3580,25): Isole allegate...
> > GRASS_INFO_END(3580,25)
> > GRASS_INFO_MESSAGE(3580,26): Centroidi allegati...
> > GRASS_INFO_END(3580,26)
> > GRASS_INFO_MESSAGE(3580,27): Numero di nodi: 42
> > GRASS_INFO_END(3580,27)
> > GRASS_INFO_MESSAGE(3580,28): Numero di primitive:42
> > GRASS_INFO_END(3580,28)
> > GRASS_INFO_MESSAGE(3580,29): Numero di punti:42
> > GRASS_INFO_END(3580,29)
> > GRASS_INFO_MESSAGE(3580,30): Numero di linee:0
> > GRASS_INFO_END(3580,30)
> > GRASS_INFO_MESSAGE(3580,31): Numero di confini:0
> > GRASS_INFO_END(3580,31)
> > GRASS_INFO_MESSAGE(3580,32): Numero di centroidi:0
> > GRASS_INFO_END(3580,32)
> > GRASS_INFO_MESSAGE(3580,33): Numero di aree:0
> > GRASS_INFO_END(3580,33)
> > GRASS_INFO_MESSAGE(3580,34): Numero di isole:0
> > GRASS_INFO_END(3580,34)
> > C:\>v.surf.idw input=tmp1336482424014 npoints=8 power=2 column=dtm10m
> > GRASS_INFO_ERROR(2036,1): G_malloc: impossibile allocare 112768 bytes a
> > main.c:169
> > GRASS_INFO_END(2036,1)
> > C:\>g.region rast=output
> > GRASS_INFO_ERROR(2012,1): Mappa raster <output> non trovata
> > GRASS_INFO_END(2012,1)
> > C:\>r.out.gdal -c createopt="TFW=YES,COMPRESS=LZW" input=output
> > GRASS_INFO_ERROR(1348,1): Mappa raster o gruppo <output> non trovato
> > GRASS_INFO_END(1348,1)
> > C:\>exit
> > View this message in context:
> http://osgeo-org.1560.n6.nabble.com/Sextante-plugin-works-except-with-GRASS-tp4958903p4960419.html
> > Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> > Qgis-user mailing list
> > [hidden email] <http://user/SendEmail.jtp?type=node&node=4961106&i=1>
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> [hidden email] <http://user/SendEmail.jtp?type=node&node=4961106&i=2>
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/Sextante-plugin-works-except-with-GRASS-tp4958903p4961106.html
> To unsubscribe from Sextante plugin works except with GRASS, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4958903&code=cGllcmlnaXNAZ21haWwuY29tfDQ5NTg5MDN8MjMwODY1MTQ5>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/Sextante-plugin-works-except-with-GRASS-tp4958903p4962479.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120509/c2fa2789/attachment.html>
